max power raiting / boost for percision 440cc injectors
Old Jun 8, 2010 | 10:58 PM
wtsapexipowerfc's Avatar
Default max power raiting / boost for percision 440cc injectors
Just wondering what I can get out of 440cc precision injectors.
max boost/power wise
going to be running a t3 50 trim
on a built low comp d16z6
Old Jun 9, 2010 | 05:34 AM
PrecisionH23a's Avatar
Default Re: max power raiting / boost for percision 440cc injectors
Around the 300whp marker.
Old Jun 9, 2010 | 06:58 AM
according to the RC injector calculator
the 440s are only good up to 230whp..
Old Jun 9, 2010 | 07:52 AM
TheShodan's Avatar
Moderator
440cc is good to about 230-250whp at the most. This is based upon 43psi of fuel pressure. It is risky to raise fuel pressure above the capacity of the injectors just to claim that it can perform more power than it can.
Old Jun 9, 2010 | 08:16 AM
raene's Avatar
Their test results are typically based on low-rpm chugger engines. Change the BSFC to a bit lower and you'll get more accurate results for our engines.
Also note that you'll run out of injector a lot faster if you take the engine higher.
I've personally taken 450s to above 270hp at 45psi base fuel pressure. Would not recommend, however.
turbodailydan
Jul 25, 2009 05:45 PM
Civic89stdB16
Feb 22, 2009 12:26 PM
pg_vtec
Sep 28, 2006 03:39 PM
hybrid_vtec
Jun 28, 2005 09:39 PM
Islander
Sep 28, 2001 07:17 PM
