780cc p&h with E85. how much Power.
Re: 780cc p&h with E85. how much Power.
If you are close to your power goal and maxed on duty cycle, raise fuel pressure. Going from 45psi stock to 60psi will net you around 920cc flow rate. It would be best to check with manufacturer first though to determine the maximum safe fuel pressure. Some injectors actually develop a better spray pattern at higher than default pressure.
koczeka
10-30-2008 08:52 AM
94typeR
06-22-2007 07:44 PM
