timing belt wont fit with low comp. head gasket....now what?
Old Jun 8, 2010 | 09:20 PM
01ethansh's Avatar
Default timing belt wont fit with low comp. head gasket....now what?
i got a b16 ef pr3 head p30 block with stock pistons so im using a 2.5mm head gasket and water meth injection instead of goin forged, the problem i have now is that the timing belt will NOT fit...so my question is do "they" sell slightly larger timing belts or a more adjustable tensioner... i also tried using a p72 timing belt but it was much too large... i would appreciate any help thanks
Old Jun 9, 2010 | 05:43 AM
ValleySyder's Avatar
Default Re: timing belt wont fit with low comp. head gasket....now what?
use a b16 belt trust me it will fit .. grab a helms manual to help you out .. u are clearly not doing it right ..
and i do not know of any larger timing belts
Old Jun 9, 2010 | 12:17 PM
andrew54's Avatar
also depends on the water pump make sure vtec water pump. They have two different sizes vtec and non.
Old Jun 10, 2010 | 12:35 PM
01ethansh's Avatar
when u say clearly not doing it right does that mean im am supposed to stretch it because it will clearly not fit with out doing so i have been using the haynes manual aswell and have been using the recomended method....with the tensioner pryed as far as it will go the belt with no slack is still a whole tooth length below the cam gear...trusting u does not make it easier my man thanx tho
Old Jun 10, 2010 | 02:02 PM
95dxsir2's Avatar
i had no problem with mine. b16, stock cam gears, .072" head gasket.
Old Jun 10, 2010 | 02:30 PM
01ethansh's Avatar
really no problems.... i got the .096 i believe and been fn with it everyday with no luck.... i start at the crank then to the tensioner then pump then cold then hot cam gears but theres no way i can stretch it over the intake cAM sprocket is there another order
Old Jun 10, 2010 | 02:59 PM
Turbo-LS's Avatar
the ls tbelt is longer than b16 but shorter than p72 try that. but like stated the stock on should fit
Old Jun 10, 2010 | 04:30 PM
90blackcrx's Avatar
Bigger muscles are needed
Old Jun 10, 2010 | 04:35 PM
intense4thgen's Avatar
it should be going in this order, crank-exhaust cam and then installing the intake cam last. on the water pump it will say either 22t or 19t you need to match the correct belt to the pump hope that helps
Old Jun 10, 2010 | 06:59 PM
joppe's Avatar
I think your problem is that it doesnt fit exhaust cam to crank cause of headgasket. Use adjustable cam gears, i have to fit it like that because i have milled so much head for more compression ratio d16 with vitara.
Old Jun 11, 2010 | 05:56 AM
kyden's Avatar
adjustable cam gears isn't gonna help his problem with the belt not fitting on there.
Old Jun 11, 2010 | 09:07 AM
95dxsir2's Avatar
why so thick of a headgasket?
i was around 9.2ish :1
LOW_ONBILLETS
Honda Fit
Dec 19, 2011 08:33 PM
obliviousSI
Oct 18, 2006 12:42 AM
mycivic93dx
Jul 3, 2005 06:57 AM
1hotintegra
Jun 16, 2003 03:10 PM
infamousALLMTR
Feb 25, 2003 07:16 PM
