Gas Pump Stops Early
Old Jun 8, 2010 | 07:34 PM
jaebekae's Avatar
Default Gas Pump Stops Early
If I slowly fuel the tank, manually, it'll be okay. But If I pull the handle all the way and set it alone, it will stop within seconds.
I'm assuming the tank isn't letting out air fast enough when fueling the car. What things can I check to see if this is the case? I have tried twisting the nozzle upside down and side ways, still no go.
Old Jun 8, 2010 | 07:51 PM
phootbag's Avatar
Default Re: Gas Pump Stops Early
I replaced a fuel tank in a Honda Pilot for the same symptom. There is an over-fill valve inside the tank. I believe it was stuck causing the symptom. The vehicle was fixed after replacing the fuel tank. The valve was integral and not replacable on it's own.
Old Jun 8, 2010 | 08:25 PM
jaebekae's Avatar
how much did that cost?
Old Jun 8, 2010 | 08:54 PM
phootbag's Avatar
Didn't cost me a dime!
Cost the customer the part, don't recall how much, and I did it in a couple of hours which included a thorough EVAP test afterwards along with a trip to the gas station. Pretty generous on my part, if you ask me.
Old Jun 8, 2010 | 08:56 PM
jaebekae's Avatar
Willing to help me out?
91cb7h23
Feb 10, 2013 04:13 PM
Hondaisok
Sep 27, 2010 09:30 AM
folta2169
Jul 31, 2007 12:53 PM
kaoss_11
11
Dec 9, 2004 08:29 PM
Zooper
22
Aug 15, 2004 09:45 PM
