Trunk pop wiring
Old Jun 8, 2010 | 04:38 PM
zsudz922's Avatar
Default Trunk pop wiring
so i have a couple questions regarding a trunk pop solenoid installed with my alarm. where do i install the trunk pop button when i am also using my alarms AUX wired like this -
also will a fused 18ga. wire straight from the battery be sufficient to run it?
thanks!
Old Jun 9, 2010 | 05:57 AM
fcm's Avatar
fcm
Old Fart
Default Re: Trunk pop wiring
Need to know what the current draw of the solenoid is to know what gauge of wire to use.
If you also want to install a "manual" button for trunk/hatch release then connect one side to chassis ground and the other to #85, same place as the alarms control lead. 94
Old Jun 11, 2010 | 07:25 AM
zsudz922's Avatar
thanks you!
i have no idea what the draw of it is.
Old Jun 12, 2010 | 07:13 PM
fcm's Avatar
fcm
Old Fart
Did it come with a fuse or fuse recommendation? 94
98civdx
Audio / Security / Video
11
Jun 1, 2010 09:01 PM
db8int3gra
Feb 16, 2009 04:46 PM
bpr0422
Jul 15, 2006 03:48 AM
sTraNdeD
Jul 2, 2004 06:37 PM
blackEyEdpEas
Jun 3, 2004 06:13 PM
