affects of a bad wheel bearing?
Old Sep 13, 2002 | 10:14 AM
Charlie Moua's Avatar
Default affects of a bad wheel bearing?
does it slow the car down due to more rotational frition? how much are wheel bearing?
Old Sep 13, 2002 | 10:46 AM
Ricky Rojales's Avatar
Default Re: affects of a bad wheel bearing? (Charlie)
Here are a few: improper tire wear, misalignment, unpredicatable handling, etc...
These examples may seem extreme, but it doesn't take too much time for things to go down hill if you ignore the problem.
If you don't know how to test for play, then get a pro to look at it for you.
[Modified by P, 2:46 PM 9/13/2002]
Old Sep 13, 2002 | 12:45 PM
ninesecrx's Avatar
Default Re: affects of a bad wheel bearing? (P)
jack the car up and wiggle the tire from top to bottom...not side to side. See if theres free play. Wheel bearings are about 50-80 bucks and whatever it cost to get them pressed in.
Old Sep 13, 2002 | 04:56 PM
performula's Avatar
Default Re: affects of a bad wheel bearing? (ninesecrx)
They might be loud too. My right rear is so loud. I think it's the wheel bearing.
roterx7
12
Jul 18, 2006 04:27 PM
Audipwr1
Nov 20, 2003 02:50 PM
Elkins911
Jun 27, 2003 05:25 PM
OneThirtyEight
Oct 30, 2001 06:03 PM
nugget8000
Sep 24, 2001 02:08 PM
