New to the swapping thing can you help a little.
I have a 93 Delsol it has a d15 non vtec in it my buddy has a d16 non vtec im going to put in it cause i just want to do a 5 spd swap in it as well so im going to do it all at once it has most everything i have the tranny engine shifter tubes axles axles an ecu but is there anything else im going to need mine is a 93 an his a 97 delsol any help will be appreciated thank you.
you'll need to reuse your alternator, distributor, intake/exhaust manifold and injectors for a plug and play experience. You'll also have an extra sensor by the crank pulley that you won't use.
If you switch all of what HondaPartsHero said, you'll be staying OBD1, but I think you'll still need a 5 speed ECU from another OBD1 d series. It should be cheap to pick one up.
ok that is awesome because the friend im getting the swap off of his dad owns a junk yard an it has like 4 92-95 delsols so i should be set lol thank you very much for the help.
civiclover88
Jul 19, 2014 08:28 AM
asianrepnsb
Jul 27, 2008 12:19 PM
