93 civic/d15b7 - What's needed to swap in a d16y7?
i have a 93 honda civic dx with a stock d15b7 its starting to knock, i found a d16y7 for real cheap wondering what im gonna have to do to make this a successful swap??
I'm not Rick!
Re: 93 civic/d15b7 - What's needed to swap in a d16y7?
jus the longblock and prolly a dif driver side engine bracket to the mount. theres alot of dif d and bseries engine brackets.
and you need to switch a few things if its obd2.
ignore the crank sensor plug in the oil pump.
get an obd1 dizzy.
mod the injector clips to fit over the obd2 injectors.
get an obd1 dizzy.
Technical Hero
just swap it in using your intake/exhaust manifolds, alternator, starter, and distributor. No need to swap over the injectors just reuse your injectors along with the intake manifold.
Would going with the B16Y7 be the easiest swap or does someone have another suggestion. I am also going from a 1993 civic with a broken crank. Thanks
d15b baby! easiest thing to do is swap a d15b(i payed $715 w/ tranny) w/ a p28($100) and a hassport v-tec subharness($70). theres no hassle, all your d15b7 stuff (intake,exhaust,sensors,ect.)is reused.
Sorry to bring back an old post My Y7 on my 94 civic died and putting back the d15b7 back in. Question i have is that my starter is from the y7 will it work with my D15b7 or foni have to buy one for the b7
