Transmission & Drivetrain Gearboxes, Differentials, Clutches
jdm YS1 gear box
Old Jun 7, 2010 | 04:48 PM
4doortypeR's Avatar
Default jdm YS1 gear box
The 3rd and 4th syncros and sleeve want to be Changed.
However my assumption was that it would be the same as the
Hydro box. The diameteer of the Syncro Sleeve is smaller than
The hydro 3rd and 4th. Can anybody shed some light, I am
Confused as the Clutch shaft is the big spline, thus the y1,S1and J1
3rd and 4th gear Syncro set won't work?
__
Old Jun 7, 2010 | 06:02 PM
David @ Synchrotech's Avatar
Default Re: jdm YS1 gear box
If the transmission has a sticker that has "YS1" on it then the internals will be the same as a hydro unit. Your M/S 3rd gear will have 24 teeth if it is a b16 or B17 GSR and 26 teeth if it is an LS. The LS uses a smaller sleeve and synchros than the B16/GSR. The YS1 will have 3 shift forks on 3 individual poles where the early 88-91 B16 transmissions S1/Y1/A1/J1/Y2 use 3 shift forks with 2 poles. The J1/Y2 use a larger 3/4 sleeve than the 5th and the S1/Y1 have 3/4/5 synchros the same size.
My_EFsedan
Mar 26, 2010 10:04 PM
anrkii
Sep 24, 2007 10:36 AM
JohnnieChimpo
Apr 9, 2006 02:10 PM
JohnCRX
Mar 2, 2006 01:25 PM
