car gets hot when im stopped. Any ideas?
Old Jun 7, 2010 | 03:40 PM
xTomei's Avatar
Default car gets hot when im stopped. Any ideas?
After I drive my car for a few minutes the temperature stays at the normal spot, but when I come to a light it rises pretty fast. First thing I did was a radiator flush and replaced the thermostat. I just realized the fan isnt turning on when it should. Do I need a whole new fan or a relay? Also when I turn on the a/c the radiator fan still doesnt turn on, but the a/c fan does.
Old Jun 7, 2010 | 03:43 PM
shawn_crx's Avatar
Default Re: car gets hot when im stopped. Any ideas?
Its your fan..
check fan switch/relay/fan motor.
** check all connection/wires first
Bypass fan switch, if it works, then change your fan switch.
Bypass relay, if it works, then it's your relay
hook fan straight to battery, if it don't work, then it's your fan motor.
Old Jun 7, 2010 | 04:39 PM
mondojackal's Avatar
When was the last time the water pump was replaced? That could be making the "fan not turning as much as it should be" situation much worse.
Old Jun 7, 2010 | 04:40 PM
87 SiviK Si's Avatar
Originally Posted by shawn_crx
Its your fan..
Do this.....
Old Jun 7, 2010 | 04:57 PM
xTomei's Avatar
not to sound like a retard, but how would I go about bypassing the switch?
I checked the relay and it works fine. The guy I got the car from said the waterpump just got changed 3 months ago. But he also lied about some other stuff so theres no telling.
Old Jun 7, 2010 | 05:01 PM
1badteg's Avatar
i wouldnt bypass the switch to the fan because it will always run. i would check your fan fuse to be honest. its usually something as simple as blowing a 40A fuse in the fuse box under the hood. there should be a fuse for the rad/fan relay. if it gets overloaded in heat then it usually blows. check that and then check your wiring.
Old Jun 7, 2010 | 05:05 PM
You bypass the switch to troubleshoot, not as a permanent fix.
Old Jun 7, 2010 | 05:07 PM
xTomei's Avatar
Yes. But, how do I bypass them to check? run wires to the battery? where would I hook the wires to?
Old Jun 7, 2010 | 05:15 PM
nothing_shocking's Avatar
To test the fan motor, just run two wires from the battery right to the fan. Unplug the fan and make sure you hook ground to ground and power to power. If it turns on, the fan is good. I think that's what you're asking for...
Old Jun 7, 2010 | 05:23 PM
D16SiHatch's Avatar
to bypass the switch pull it off the thermostat housing and connect a piece of wire to the 2 terminals inside the plug. if the fan turns on then the relay is good and the switch is bad. if the fan does not turn on then either the relay is bad, or there's an open in a wire.
Old Jun 7, 2010 | 06:02 PM
xTomei's Avatar
Thanks for all the help. I figured out that its the cooling fan switch.
That's a lot easier than switching out a water pump, which is what I was going to do on Wednesday.
dsettlemoir
Jul 2, 2016 01:00 PM
fatl13ert
Oct 22, 2012 12:41 AM
19 crx 89
10
Aug 26, 2010 12:38 PM
littleblue
Oct 14, 2008 04:44 AM
ViXoN Hatch94
Feb 4, 2006 07:53 PM
