Suspension & Brakes Theory, alignment, spring rates....
civic front sway bar???
Old Jun 7, 2010 | 02:29 PM
ej1gsr!'s Avatar
Default civic front sway bar???
i got a 94 civic ex with stock front sway bar n i want to upgrade a little in the front
so ma question is is the ls bigger than the civic???? and can i use civic flcas or do i need the integras????
wat size is civic>?? ls.?? and gsr???
thanks in advance
Old Jun 7, 2010 | 04:43 PM
Relic1's Avatar
Default Re: civic front sway bar???
civic = 22mm
LS/GSR/ITR = 24mm (DC2)
yes the Civic Flcas will work fine with the teg sway, all though you will need different end links (from the teg) and bushings (from teg)
one thing to think about, the rear sway does more to the handling on our cars than the front.
If you don't have a rear sway I'd look into that before thinking about bumping up your front. It will do 1000x more than the 2mm front increase. (in fact that will increase understeer, the opposite of what you likely want)
Old Jun 7, 2010 | 05:56 PM
egsleepercivic's Avatar
Originally Posted by Relic1
civic = 22mm
ls should have same endlinks as the civic, it's the gsr and itr that have the different endlinks, which are about $50 a piece
you can see this difference in this diagram http://www.hondapartsunlimited.com/i...&submit=submit
Old Jun 7, 2010 | 07:11 PM
ej1gsr!'s Avatar
ok so ls/gsr/itr sway bar bigger than civic n wat endlinks do i need?
ej1gsr!'s Avatar
civic = 22mm
thanks i already got asr24mm:-) just trying to upgrade the front
Old Jun 7, 2010 | 07:46 PM
ej1gsr!'s Avatar
ok i heard that i can use the 99 civic si which is 26mm compare to gsr/type r 24mm but i need to use type r endlinks>>??
can anone verify this pls???
Old Jun 7, 2010 | 08:59 PM
98civdx's Avatar
Master Detailer
To use the 99-00 civic si sway bar you need 99-00 si front lca's
the sway bar isnt compatable with any other type of lca.
Old Jun 8, 2010 | 07:51 AM
ej1gsr!'s Avatar
well i fund this info ????
Front Lower Control Arm compatibility:
Civic EX and HX front LCAs should be used when adding or upgrading to:
- 1992-1995 Civic Si
- 1992-2000 Civic EX
- 1994-1997 del Sol DOHC
- 1996-2000 Civic HX
- 1994-2001 Integra LS
- 1994-2001 Integra GSR
- 1996-2001 Integra Type R
Civic Si front LCAs* should be used when adding or upgrading to:
- 1999-2000 Civic Si
- 1997-2000 Civic Type R
If you already have an EX/HX LCA and would like to upgrade to the Civic Si or Civic Type R front bar, you can do so using Integra Type R endlinks documented below.
*Civic Si front shock forks need to be used as well when upgrading to the Civic Si/Civic Type R front lower control arms.
Old Jun 8, 2010 | 07:56 AM
ej1gsr!'s Avatar
i found some info can anyone verify this it says that if i already got ex flcas i can runs 99-00 civic si front sway bar with type r end links
http://www.jdmuniverse.com/forums/view_ekswaybars.html
Old Jun 8, 2010 | 12:16 PM
98civdx's Avatar
Master Detailer
well, that information is new to me. I have never seen anyone use a SI/CTR front sway bar with any other type of lower control arm.
In the picture that is shows the si sway bar with itr endlink, it looks to be hanging under the lca, which i dont like at all.
With my SI front sway bar, i already drag the damn thing over speed bumps, with si lcas.
Old Jun 8, 2010 | 12:47 PM
ej1gsr!'s Avatar
ok thanks for the info i guess ill just upgrad to gsr sway bar
thanks thou^^^^^
Ukrainamese
Suspension & Brakes
21
Dec 8, 2013 08:32 AM
94allmotor
Sep 2, 2007 12:56 PM
superman3503
May 24, 2006 03:52 PM
DIP_SET FoReVr
Dec 19, 2004 02:08 PM
