cooling fan fuse keeps blowing
Old Jun 7, 2010 | 01:18 PM
Lil_Wyte's Avatar
Default cooling fan fuse keeps blowing
two years ago i picked up a fal fan and fluidyne rad for my 92 civic, no problems at all until about two weeks ago, now that the weather is getting hot i keep blowing fuses, the fan only draws 9.5 amps and its a 15 amp fuse, if i put a new fuse in it will work for a bit then crap out. is the motor going on the fan or??...checked for a short in the wires, but found nothing...what else should i do? please help!
thanks
Old Jun 7, 2010 | 02:40 PM
Lil_Wyte's Avatar
Default Re: cooling fan fuse keeps blowing
also now, i put in a new fuse, went for a drive, fan didnt kick on so everything was good, got home let it idle, fan came on for 2 seconds then the fuse popped, turned the car off and installed a new fuse, turned on the ignition not start the engine, and fan ran completely fine until it turned off, fuse didnt blow....im sooo confused
Old Jun 7, 2010 | 07:16 PM
Lil_Wyte's Avatar
bump anyone????
Old Jun 7, 2010 | 07:35 PM
mechanix619's Avatar
Try using a 30amp fuse. Did you wire the fan with a relay or just off the existing wires?
demiseraph
Aug 5, 2011 05:12 PM
trustdestruction
Mar 30, 2009 03:11 PM
b00sted4dr
Jul 25, 2005 05:28 AM
LonelyDriver02
Aug 14, 2004 03:41 PM
