h22a (type s/sir)???
Old Jun 7, 2010 | 12:25 PM
lexrob's Avatar
Default h22a (type s/sir)???
does everyone still have no idea how to tell the diff. between the
220""hp H22A and the normal ..200hp H22A
I know valve covers were diff. colors but mine came color matched so yea.....
lexrob's Avatar
Default Re: h22a (type s/sir)???
may be dyno is the only way haha...
Old Jun 7, 2010 | 12:38 PM
Kronn 98SH's Avatar
Well....The Type-S engine will be exactly like a Type-SH engine with regards to oil filter and ATTS mounting. That's the easiest way to rule it out. As for the SiR S-spec vs any other H22A, the serial number can be used. There's a thread somewhere (not necessarily on H-T) that explains the breakdown of the JDM H22A serial numbers.
Old Jun 7, 2010 | 12:47 PM
nsxter's Avatar
wrong the The Type-S engine is not exactly like a Type-SH engine with regards to oil filter and ATTS mounting. for the 220 hp h22 the head will be stamped p5p and so will the pistons , unless a stock motor was altered
Old Jun 7, 2010 | 01:47 PM
Kronn 98SH's Avatar
Really? What's the difference?
Old Jun 7, 2010 | 04:37 PM
oneprelude's Avatar
Wrong dude!!!! The head does not stamped P5P. The block and intake manifold have P5P stamps. Pretty much the same as an SH
Old Jun 7, 2010 | 05:47 PM
nsxter's Avatar
then tell me why my head is stamped p5p
Old Jun 7, 2010 | 10:14 PM
kornkid21792's Avatar
lol why are you all making this as complicated as possible.
if this is a stock motor first thing that would be a dead give away is the cams. a true type s cams have a blue tint to them. and as well a true type s has 11:1 compression. as i stated above a cam inspection is the easiest way to tell.if you bought the motor and was advertised as type s check the cams for blue tint. if its not there get your money back.
and if you bought it from a buddy or sm1 claiming type s and no blue tint cams then its not a true type s
Old Jun 8, 2010 | 01:23 PM
oneprelude's Avatar
My bad, what I'm trying to say is not all Type S's come with P5P stamps, there are PDE/ P13.Hey Kronn, you have an SH right? Is yours stamped P5P
Old Jun 8, 2010 | 01:57 PM
Kronn 98SH's Avatar
My head has a WP5P sticker and a P13 HF-2 stamp. My IM has a P13 HF5 stamp.
Old Jun 8, 2010 | 07:03 PM
lexrob's Avatar
so blue tints the only way ....besides finding the comp. ratio.... <-----thats easy hehe
Well ill check it out this weekend and let you guys know what i got.
Its got a p13 ecu LSD and OUTLAWTUNERS etched into the rear windows. Came from Main i found a pic of it on google linked to HERE hahahahahahaha.....
I just read a couple threads of his from 2007 nothin bout the swap tho. he hasnt been on since 2009 so CRAP.
jwise93
Oct 29, 2012 03:52 AM
03K24A4EX
Apr 18, 2006 08:56 AM
Cris Cara
Sep 22, 2004 09:15 AM
EGB18
Aug 8, 2004 11:08 PM
