1/4 Miles time on stock H22A/H22A1 w/header...etc.
I have a h22a1 in a eg (gutted)....my best time is 13.3 with just a simple setup. Just want to know if anyone else has a simple setup that runs a better time. Please post your time and setup
1) Intake: (Cold air)
2) Header: (stock with cut off pipe)
3) Ecu: (chip p28)
4) Tires: (22x8x13 MT)
5) Tranny: (H22 w/lsd)
3) Ecu: (chip p28)
3) Ecu: (chip p28)
3) Ecu: (chip p28)
interested also, going to the dyno this weekend and then to the track once tires get here..would love to get the times IGOTK22 has with my full weight ej6.
3) Ecu: (chip p28)
3) Ecu: (chip p28)
i have done this identical setup several times in the past
i ran 12.8s w/ stock p13
and ran 12.6s w/ hondata
add a b16 trans and run 12.0s haha
about 10yrs ago my buddy had the same setup and ran a 13.20 but trapped 107mph so it probably had a 12.80 in it. he was having shifting problems.
Stock JDM H22 with JDM H22 Trans
Stock Cams
Hotshot header
stock intake tube with a filter (ghetto rigged)
Stock Intake Manifold untouched
Stock throttle body
Stock Head
Stock Block.
Stock trans M2B4 stock LSD
Stock Clutch!
12.6 with chipped p28 ecu at Pomona raceway in 92 Civic 4 door full interior on 13x26" slicks.
Stock Cams
Hotshot header
Stock throttle body
Stock Head
Stock Block.
Stock Clutch!
Stock Cams
Hotshot header
Stock throttle body
Stock Head
Stock Block.
Stock Clutch!
Stock Cams
Hotshot header
Stock throttle body
Stock Head
Stock Block.
Stock Clutch!
skunk 2 tuner 2 cams
ported oem intake manifold with double stack butterfly's
70mm STR TB
stock bottom end (untouched, original JDM internals)
SSR/DTR Side exit header
Chipped p28 ecu
22x8x13 M&H slicks on Bogart Pro 4's
Personal best with a h22 trans was 12.37@ 107mph (not sure on the trap)
70mm STR TB
Chipped p28 ecu
I've just learned how to drive a stick for like a year. It was my first time ever!! down a 1/4 miles...i was so nervous. I didn't expect 13.3 out of this car.....got so excited i don't know what happen to the time slip. Its just a chipped p28....
poweredbyh22
Mar 28, 2004 09:44 PM
SilverDc2
35
Apr 13, 2003 10:03 AM
