View Poll Results: Which would be better for Vitara pistons?
Leave it as it is.. i like my low compression better
23.08%
-12 cc dish is the way to go
7.69%
-11 cc dish is the way to go
69.23%
Voters: 13. You may not vote on this poll
Gauging Interest: New Vitara piston
Old Jun 7, 2010 | 09:45 AM
fjt's Avatar
fjt
Default Gauging Interest: New Vitara piston
Well guys i need all of your serious input on this one.
I am currently trying to decide on making a change to the current version of YCP Vitara piston. It will be a piston sold exclusively through FJ Distributors and other dealers that decide to stock these pistons as well.
I have been debating into making the piston to provide better compression as this has been one of the major requests/complaints from customer. We intend to achieve this by changing the dish specs on the pistons. YCP Has already gave us the OK on doing this but i just need to figure out which compression will be ideal.
Now keep in mind that it will be 1 piston design for all D series honda so the compression ratios will vary depending on the head.
Im taking into consideration the lowest CR ratio and Highest CR ratio provided depending on heads used and try to bring those number to a happy medium.
Now this is what it looks like with the current version of the pistons.
Lowest CR (With the FJ R spec Custom Length rods)
D16A6 full engine/Head, 75mm---> 8.03
JDM D15b full engine/Head, 75mm---> 8.02
ZC Dohc full engine, 75mm--> Approx 7.9:1
Highest CR (With the FJ R spec Custom Length rods)
D16Y8 full engine, 75mm pistons ---> 8.74
Now according to my calculations bringing the dish to -12cc will have the following effect in compression.
D16A6 full engine/Head, 75mm---> 8.42:1
JDM D15b full engine/Head, 75mm---> 8.40:1
ZC Dohc full engine, 75mm--> Approx 8.2:1
D16Y8 full engine, 75mm pistons ---> 9.22:1
bringing the dish to -11cc will have the following effect in compression.
D16A6 full engine/Head, 75mm---> 8.56:1
JDM D15b full engine/Head, 75mm---> 8.50:1
ZC Dohc full engine, 75mm--> Approx 8.36:1
D16Y8 full engine, 75mm pistons ---> 9.39:1
Even on the projected new rods for the USDM D15 this improvement should make the compression in the mid 8's... otherwise it would be in the 8 flat or 7.8-9's
Old Jun 7, 2010 | 11:35 AM
91jdmhatchback's Avatar
Default Re: Gauging Interest: New Vitara piston
Will the old vitara's still be available? Some like the low comp.
Old Jun 7, 2010 | 05:23 PM
daveb91's Avatar
having a A6 id like a -11c. Is this something that is going to happen soon???
Old Jun 7, 2010 | 06:20 PM
Turbo1.6's Avatar
The -11 cc dish would be my choice. What would the ratio be for a D16Z6 setup?
Old Jun 7, 2010 | 06:46 PM
95civhb's Avatar
^^x2... ?
I'd be in favour of a higher compression piston... A little less boost to have to run for a DD is good
Old Jun 7, 2010 | 07:57 PM
Originally Posted by 95civhb
^^x2... ?
No offence but boost pressure has nothing to do with anything. 10 lbs at 300hp is just as reliable/unreliable as 20+lbs at 300hp. Boost pressure is just a number, as hp is more relevent.
Old Jun 8, 2010 | 08:48 AM
wmac's Avatar
the closer to the nines, the more i like.
-11 cc.
Old Jun 8, 2010 | 12:01 PM
ReDemoN's Avatar
DixielandImports Please
I like the idea.
But im fixing to change to some forged units.
Old Jun 8, 2010 | 01:54 PM
fast2camciv's Avatar
some 81/81.5mm ycp's would make me happy in my pants
my vote is to get up to 9.5:1 using d16z6 specs (seems to be most popular) and let the rest fall where they may....
Old Jun 8, 2010 | 02:31 PM
slywfbpsi's Avatar
the -11cc would work fine with me.
Old Jun 8, 2010 | 02:50 PM
95civhb's Avatar
It's not a matter of reliability. Everything that I have ever heard would suggest that running an engine at a lower boost level (everything else equal) is healthy for a motor than a higher boost level.
I guess the argument could be made that so long as the tune is correct, things should be fine, however, intuitively, the argument that higher boost could put more stress on some components would seem to be reasonable. I do see what you're saying, everything I've ever heard though seems to be the opposite..
The theoretical physicists can chime in with expertise on that one though...
Old Jun 8, 2010 | 08:38 PM
d112crzy's Avatar
It's not boost levels that matters, but peak cylinder pressure. You can have a high peak pressure with "low boost", while a motor with "higher boost" can have lower peak pressures. The lower boost will see more stress if the cylinder pressure is higher.
But all this is off topic.
Old Jun 9, 2010 | 12:50 AM
GEN2 LS's Avatar
Loved
we need something like this for b-series budget guys:p
Old Jun 9, 2010 | 06:18 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Please contact InternetBrands about our vendor offers here on Honda-Tech.com
Thanks
smartass
Jan 8, 2008 04:30 AM
high_revs
Jun 17, 2005 09:40 AM
totalimpact
Dec 9, 2003 03:48 PM
greengangsta
Mar 18, 2002 07:23 PM
C-speed
Nov 12, 2001 05:52 PM
