D4 light is blinking, CAR WONT START, 2000 Prelude Auto...Please help
The car was running fine, i didnt notice anything different before it crapped on me. turned the car off, less than 5 minutes later i tried to start it and nothing.
The D4 light blinks, as soon as the key is in the ON position.
The Gear Selector on the dash moves and lights up according to the shifter.
The Engine turns over, but car wont start in any gear; (P, R, N, D4, etc.)
Where should i start? Car is a 2000 Prelude with a Crap-Tronic Transmission.
i tried getting the engine codes off of the car but when i jump the blue connector (next to the OBDII connection), and try to retrieve the codes, nothing happens....
also, the fuel pump doesnt kick on when i turn the key to the ON position..
Are you sure that you used the correct holes? The clip that you jump has 4 holes in it. Only two of those holes have electrical connections.
yes Kron, i used the two holes with the pins in them. i did most of my reading for this in one of your old threads.
none was taken, thanks Kronn! sorry if i came off brash, its not what you say but how you say it right?
THE CAR GODS SMILED ON ME TODAY!!!!!!
i was racking my brain trying to figure this out... i was checking the brake switch ( i know it wasnt this, but i was getting anxious), and i noticed 1 little black wire that had come undone....plugged it in...no D4.... car started right up...DOH!!!!
thanks to all that replied!!!!!!
SaltyMillennial
Dec 20, 2023 10:51 PM
wantalude
Transmission & Drivetrain
Jun 25, 2010 02:40 PM
