scratching sound when reving above 3000 rpm
Its probably a heat shield that has worked its way loose. Jack up your car when it is cool and check to see if any of the heat shields on the exhaust are loose. If a heat shield is loose between the exhaust and the ground you can usually just take it off, but don't park in tall grass or you may start a fire. If the heat shield is between the exhaust and the vehicles body, I wouldn't reccomend taking those off because the exhaust can heat up the fuel tank over a long drive.
It is amazing what you can think is wrong with your car when it is just a heat shield.
CarGuy91
Honda CR-V & Element
Nov 14, 2013 04:53 PM
wellbuiltaccord
Dec 17, 2012 08:39 PM
Integra4lyfe069
Mar 16, 2012 07:03 PM
