Building a B20V - need machine shop info ASAP
Old Jun 6, 2010 | 08:29 PM
victor.ek4's Avatar
Default Building a B20V - strange sleeve casting..
EDITED.
please go to post #7
Old Jun 7, 2010 | 11:13 AM
victor.ek4's Avatar
Default Re: Building a B20V - need machine shop info ASAP
anyone?
Old Jun 7, 2010 | 11:54 AM
092eg6's Avatar
I dont kno in miami but here in CA i get it done for this much:
hone cylinders- 20 bucks
Install ARP bolts- 30 bucks
Resize rods- ????
press rods on pistons- 20 bucks
micro polish crank- 20 bucks
align hone (if necessary) $100
Crank balancing $100
check honda manual for honing process!
Old Jun 7, 2010 | 01:27 PM
victor.ek4's Avatar
Well, I found those 2 machine shops that seem to be good.
One is
Mesa Balancing
(305) 884-5368
1075 E 16th St, Hialeah, FL 33010
the other is
South Florida Crank and machine
525 S H St, Lake Worth, FL, 33460
561-533-9932
What do you guys suggest? Ive heard that both are really expensive, but I don't care to pay more if a good job is done!
Old Jun 7, 2010 | 08:04 PM
jmart41791's Avatar
my machine shop doing my.b20 is charging me about $500 bucks to bore and hone, deck, micropolish crank, balance the rotating assembly, and jet wash. I don't know if that's expensive because it is my fiat experience with a machine shop. just my $.02
Old Jun 7, 2010 | 08:43 PM
victor.ek4's Avatar
I think that balancing the rotating assembly is the most expensive part, probably worth of $150 out of this $500...
I have around $300 to spend, I hope the block doesn't need to be decked, or aligned. And I don't care for jet wash, I can wash and clean the block myself.
Old Jun 21, 2010 | 03:37 PM
victor.ek4's Avatar
I noticed that the sleeve is way thinner in one side, they are perfectly aligned with the HG, it seems like the casting is out of center idk if that is possible..
Now, is that gonna be a big problem? It's going to be the first B20Vtec in my country so I have 0 experience with this sleeves..
I plan to keep the revs lower than 8500, if possible, arround 8200˜8300 rev limit to give the motor a longer life. THe whole setup is designed for this area.
Old Jun 21, 2010 | 03:47 PM
nsxter's Avatar
for an rpm of 8500 there really is no need to balance the bottom end honda motors are balanced very well from the factory unlike v8 builds
Old Jun 21, 2010 | 03:54 PM
victor.ek4's Avatar
Well, I picked the motor up at Mesa balancing today, the crank was untouched, it is in such a good condition, I don't want to mess with it.
But my concern now is with the sleeves
Old Jun 21, 2010 | 05:29 PM
PyroProblem's Avatar
It looks like the thin side is on the exhaust side correct? Thats also the thrust side during the power stroke...Hmmmm...Do you usually have good luck?
Old Jun 21, 2010 | 06:42 PM
victor.ek4's Avatar
It is in the intake side..
And no.
I don't have good luck.
And I just payed shitloads for machining, I can't just not use this block =s
**** i'm scared
Old Jun 21, 2010 | 06:53 PM
Go for it and cross your fingers! You already got alot of time and $ into it. If it works great! If the sleeve cracks, youll probably have symptoms of a blown headgasket and possible oil/coolant mixing...
Old Jun 21, 2010 | 06:55 PM
Combustion Contraption's Avatar
Dont worry about it. For what you are planning to do, you will be absolutely fine.
Old Jun 21, 2010 | 07:10 PM
victor.ek4's Avatar
Thanks for the good input.
I will try to keep the revs down, fingers crossed, and be extremely cautious with the tune.
Old Jun 22, 2010 | 03:52 PM
Good luck and keep us updated after it gets all together. Curious to see what your personal experience is with them.
Old Jun 22, 2010 | 05:50 PM
victor.ek4's Avatar
hahahaha, sometimes when I look at this side of the sleeve, I feel like I have a 87mm B20 on stock sleeves.
LOL
Old Jun 23, 2010 | 07:37 AM
victor.ek4's Avatar
Damn this is really frustrating..
This block is going to cost me arround 1400$ to get it in my country, with papers and stuff, shipping, bla bla..
I'm gonna take my chances I guess... It's my only option now. When this things break, they usually collapse and blow the **** out of the engine, or just crack and overheat?
Does somebody know if it is possible to sleeve this block with regular dry sleeves?
Old Jun 25, 2010 | 09:50 PM
jmart41791's Avatar
don't feel too bad.I just got slammed with a 1500 dollar machine shop ticket this week
CRXherbie91
Mar 8, 2009 08:43 PM
Greyout
Jun 17, 2003 10:41 PM
Slick GS-R
May 5, 2002 05:27 PM
Slick GS-R
May 5, 2002 08:52 AM
B20LS-T
Apr 18, 2002 06:14 AM
