obd2 to obd1 single or d-series step down help
So I need help on making my 98 d16y7 obd2a motor to work properly into a 94 honda civic what do I need to change so it can work properly in a obd1 car.
I know I hae to chang the injectors, alternator, starter,distbutor,intake manifold,and i also need a step down do i need anything else
correct me if im wrong, but assuming you have the OBDII engine harness wouldnt it be easier and possibly cheaper to just use an OBDII ecu and pin out the dash harness.
^^ I know that this my first time using this site I know I have to change all that just want to make sure If that's all I have to change and thanx to da help I have boys that have done this like I said just want to double check
