15x7 +20 on a ej6
can i get away with just rolling my fenders?
height wise in around half way ticking tire on a 195/55/15 wheel
btw new wheels are enkei 92
any oics would be nice too thanks
Should be able to fit with rolled fenders and natural camber. Heres mine with 15x7 +40 with a 15mm spacer making it fit like a +25.
front spacer only with roughly -2 degrees camber and 195's
hey man i know im a few mths late to find your post, but ive got the almost the same tire setup you do (50's) and im slammed on function and forms tuckin looots of tire. cranked all the way down. i have not rolled the fender and my oil pan is 3 finger widths off the ground, and im fine. be sure to get a good alignment. camber is not an issue AT ALL, long as your toe is set straight. im a -4 in the rear and tires are perfect. pull out the inner fender wells so your tires dont, and i took a baseball bat and did the poor mans method of rolling the fender lip under. i havent had any issues and my junks dragggin. so gl man!
