please help d15b vtec problem
i just bought a d15b with p08 ecu it was throwing a 21 for vtec sensor so i changed the to portion with an american vtec sensor and now its throwing a 22 for vtec oil pressure i dont have the green sensor as it did not come on the d15b so i am wondering if the vtec sensor does both on the d15b and thats why the american sensor did not work please advise
thanks in advance
thanks in advance
P08 ECU will look for a vtec pressure switch (VTPS) OBD1 D15B vtecs came with a pressure switch so i'm guessing you actually ended up with the OBD2 3 stage vtec version.
single switch but did not come with the green switch came with a plug in where the green switch would be asked on a different forum and they said it didnt need it but if it does thats an easy fix
hey please help, im having trouble with me vtec not working, i think i did everything. there is no CEL and oil level is fine. i have a d15b running a p28 5 spd. i did have 2 CEL, both for vtec, but i fixed that thinking it would fix vtec, but nope! i changed TPS and still nothing, vss is good. please help, thanks!
green91
Dec 29, 2004 06:43 PM
