CEL, is it a possibility?
Old Sep 13, 2002 | 07:44 AM
b16wannaride's Avatar
Default CEL, is it a possibility?
Right now i have no secondary o2 sensor on my 2000 Si,
First i started out with code 65 (bad o2 sensor).
Recently i checked the codes as my car felt really crappy...
Now i am getting codes for my
1) Air-Intake temperature
2) Throttle position Sensor
3) Engine Coolant Temperature
4) System too Rich
I think its caused by the o2 sensor not being in. Tell me what you think.
Old Sep 13, 2002 | 08:05 AM
letsride's Avatar
Default Re: CEL, is it a possibility? (b16wannaride)
Have you put in the sensor and tried resseting the ECU? Try that first and see what happens. BTW are you running a test pipe?
Old Sep 13, 2002 | 08:10 AM
Default Re: CEL, is it a possibility? (letsride)
In fact I am using a test pipe
Old Sep 13, 2002 | 09:29 AM
letsride's Avatar
Wrap the second o2 in foil and tie it out of the way. Reset the ECU and take it for a drive. Keep us posted if you get any other codes.
Old Sep 13, 2002 | 03:31 PM
98civicEX's Avatar
o2 simulator, do a search a serach.
the secondary o2 sensor is just there to make sure it's reading clean air.
the o2 simulator tricks it into thinking it is. and no more CEL
Old Sep 16, 2002 | 05:52 AM
ok. i installed the o2 sensor. all the codes were gone for about a day, then i got a new code....67...something about the cat not meeting threshold performance...
I have in a test pipe..so i know thats why... i s there any tricks or suggestions to try.
Old Sep 16, 2002 | 10:38 AM
sweet's Avatar
testpipes may normally provide better performance, but i suggest installing a Carsound high flow cat for your particular needs. you can have whatever O2 locations you want on it. and better yet it keeps the air cleaner.
[Modified by sweet, 7:39 PM 9/16/2002]
Old Sep 16, 2002 | 11:47 AM
letsride's Avatar
Check your E-mail I sent you a Pic of something you need to do. It works! If you have any Q? let me know.
Old Sep 16, 2002 | 12:02 PM
Nameless RB26's Avatar
Or you can buy an 02 simulator like I did:
http://casperselectronics.com/cgi-lo...roduct=IMPORTS
Civic98KH
15
Dec 10, 2012 08:26 PM
8083tcman
Dec 31, 2008 12:55 AM
gsrvtechatch93
Mar 29, 2004 08:48 PM
comptechgsr2000
Apr 25, 2002 09:26 PM
