94 Accord Maintenance?
Old Jun 5, 2010 | 08:02 PM
Just1nK4ng's Avatar
Default 94 Accord Maintenance?
i have a 94 Accord with 106000 miles and i was wondering what is regular maintenance i have to do to keep it running well? i have AEM short ram intake and also APEXi WS2 also what i should replace?
Old Jun 5, 2010 | 09:05 PM
The-Kid's Avatar
Default Re: 94 Accord Maintenance?
I would work on the ignition system parts: Cap and rotor, spark plug wires, spark plugs.
There's also timing belt, which is supposed to be replaced every 90k miles or 105k. Get it done soon if you haven't already.
Keep up with the transmission fluid changes. I would also flush out the cooling system.
Clean out the EGR ports (refer to Accord FAQ for DIY). I think that's about it...
Old Jun 5, 2010 | 09:35 PM
Just1nK4ng's Avatar
thanks for your reply i was wondering what are good cap, rotor, spark plug wire, and spark splugs? ( good brand name or specifically for 94 accord? )
same with transmission fluid.
Old Jun 5, 2010 | 09:39 PM
The-Kid's Avatar
I think a lot of people would agree with me if I said Honda Genuine for the cap and rotor and wires. As for the spark plug, some OEM recommended such as NGK Platinums.
Assuming this is for automatic, I would definitely do some Honda ATF-Z1 (only found at the dealership). You will need 3 quarts. 6 quarts if you want to do a drain and refill.
Old Jun 5, 2010 | 09:50 PM
Just1nK4ng's Avatar
no this is a manuel 94 accord ex any other things you missed out? also i wanted to know what are good brakes, and suspension i should get for the car like brand name if any.
trizlansky
Dec 24, 2011 01:34 PM
kenwolf
Nov 21, 2010 02:06 PM
curmudgeon
Mar 9, 2010 08:31 AM
navysealsnypre
May 21, 2007 08:15 PM
Tron 2.0
Aug 13, 2006 03:12 PM
