ride too boouncy!
did u leave them in?
if u didnt install u have to jack up the car remove tire remove strut and spring or u may b able just to look after u removed the tire n see if the bumpstop is there.
Make sure you arent using the factory metal dust shields. Also make sure you tightened the suspension up with the weight of the car on the tires. The S2 shocks come with new shorter bumpstops, but for a slammed car you need to cut the bottom ring off the bumpstop.
Sterndotstern
46
Nov 9, 2005 11:44 AM
