how do u convert to power windows?
i wanted to get tints but i was thinkin that i wana convert to power windows.. so could i still get tints and use the same door and glass when i convert or do i need new glass n door panal?
I dnt understand why gettng power windows inhibits your ability to get tint and yes you need a new panel unless you want to cut holes for buttons and have a gaping hole where your crank used to be. And you dont need new windows, it's the track that becomes powered, not the window.
both door harness, window regulator with motor, relay, door panel with switches, it don't matter what year it is from 96-00 years and for the floor harness you have to get it from the same year of your car. For example, if your car is a 97 then get the one from 96-98 years and if its a 99 then get the one from 99-00 years. Because there are two different type of OBD2 for 96-00 civic years. There is OBD2A and OBD2B. Why?? because of the 99-00 Civic Si.
if you want to go OEM power window only!!
You keep the same glass. You need manual door panels because they are made for power switches...
gOSetonHall
Aug 6, 2002 09:32 AM
