EP3 WONT START!!!!!
Old Jun 4, 2010 | 06:28 PM
jaZ32*PD*'s Avatar
Default EP3 WONT START!!!!!
last week we changed out the clutch/flywheel on my brothers EP3, the clutch has been done for about a week now, but we finished assembly of battery, intake, grounding kit, and shift linkage just today..................anyways we start it & everything is good, engine sounds fine, new clutch is engaging properly, so we go to take it for a test drive and the car stalls, we start it again and it immediately dies, we start to give it some gas the car stays running but sounds like its misfiring like crazy and if you let off the throttle it dies
i really dont understand what the problem could be, cause a couple days before the clutch went out the car drove fine?
checked all sensors, vacuum lines, ignition, fuel, & air...........still nothing
i was thinking that it was the timing, but how does the timing just randomly change????? or if it did, how do u adjust it
what is a mystery to me is, how did the car run completely fine when we first started it, and now we cant even get it to stay running
any input would be greatly appreciated !!!
Old Jun 5, 2010 | 11:22 AM
mustclime's Avatar
Default Re: EP3 WONT START!!!!!
pull the ecu fuse to clear the ecu and try it again....how dud you check for fuel and spark?
Old Jun 5, 2010 | 12:03 PM
jaZ32*PD*'s Avatar
WILL DO!!! THNX
and i checked the fuel with my voltage meter all injectors are getting voltage and i pulled fuel line to see if fuel was reaching rail, and it was
and spark i had my bro crank the motor and grounded it to my screwdriver spark was visable, but probably should check all plugs
Old Jun 6, 2010 | 01:27 PM
lafonz36's Avatar
if you turn the k series motor the wrong way you can cause timing to jump always turn a k clockwise cause counter clockwise will take the pressure of the tensioner and cause it to jump
Old Jun 7, 2010 | 09:27 AM
jaZ32*PD*'s Avatar
HMMMM......GOOD TO KNOW , WOULD YOU KNOW ANY WAY OF ADJUSTING THE TIMING???
Old Jun 8, 2010 | 03:25 PM
lafonz36's Avatar
what timing do you want to adjust ignition or cam to crank
Old Jun 10, 2010 | 10:19 AM
jaZ32*PD*'s Avatar
cam to crank
Old Jun 11, 2010 | 05:18 AM
mustclime's Avatar
Have you pulled the timming chain cover and lined up all the timing marks? If you do not feel ok with doing this, you might want to take it to a tech.
Old Jul 5, 2010 | 07:19 PM
stan463's Avatar
hey honestly it doesnt sound like a timing issuse you said that if you keep it accerelated that it stays on... sound like you have a vaccum line loose...make sure that there are no cuts on the lines
onesoejourner
Oct 26, 2011 08:35 AM
PyRo20
Transmission & Drivetrain
Aug 31, 2010 01:55 PM
ch0baca
12
Nov 18, 2009 09:21 AM
aaronISthrowed
Sep 13, 2007 03:48 PM
joel
Sep 16, 2001 08:37 PM
