still wont start, just cranks, no cel
new main relay, new cap and rotor, new plugs and iridium wires, put on the new external coil yesterday, it ran for 30 seconds, wont start again
all is left is the ignitor right? or icm whatever its called in the dizzy?
Spray a quick shot of starting fluid into the intake tube while cranking the engine. If you get a few hits (fires) then you definitely have a fuel problem. Otherwise, it is probably timing or spark.
This is way too familiar... how do I go about checking for fuel issues, are there picts so I know where to spray the starting fluid?
I do have spark from external coil through dizzy to plug, I think it is fuel
great lead, your help is appreciated
I have already replaced the Igniter unit and re-soldered the Main relay unit....
it smells like its flooded at times...................
thx
[QUOTE=Spray a quick shot of starting fluid into the intake tube while cranking the engine. If you get a few hits (fires) then you definitely have a fuel problem........[/QUOTE]
thx
California98Civ
Oct 26, 2011 03:27 PM
