Airbag system help!!!
well recently i got into an accident which led my civic into a salvage tittle not good .. freakin lady.. anyways.. am still keepin it.. but the thing is that am doin the work my self.. airbags were deploy (passenger side only) but i read about the civics havin a sensor but i only found a little box which says SRS UNIT! what would i need in order to pass the DMV inspection!?
hope u guys can help! if u got some parts i can use let me know! thanks
this is all i could find for 00 civics
Inspection After Deployment
After a collision in which the airbag(s) was (were)
deployed, replace the SRS unit, and inspect the following:
1. Inspect all the SRS wire harnesses. Replace, don't
repair, any damaged harnesses.
2. Inspect the cable reel for heat damage. If there is any
damage, replace the cable reel.
3. After the vehicle is completely repaired, turn the
ignition switch on. If the SRS indicator light comes
on for about six seconds and then goes off, the SRS
system is OK. If the indicator light does not function
properly, go to SRS Troubleshooting.
BlitzSix
13
Apr 6, 2009 01:49 PM
klomast3r
Oct 5, 2005 09:48 PM
Honda97
Nov 14, 2004 09:29 AM
