chassis harness plug identification
Old Jun 4, 2010 | 12:19 PM
ucc crx's Avatar
Default chassis harness plug identification
im redoing my chassis harness in my 89 crx si and i cant figure out what these plugs do.
it seems to just send power to all the wires connected but im not sure. its located near the fuse panel under the dash
and this one is on the driver side headlight harness, its just a plug with a cap over it. im assuming its used to check the ecu codes but im not sure.
Old Jun 4, 2010 | 12:46 PM
lunalink's Avatar
Default Re: chassis harness plug identification
those dont plug into anything. just tuck them aside and call it a day
the second one is to check the timming on the car.
Old Jun 4, 2010 | 01:07 PM
EFRue57's Avatar
x2
1st one does not go to anything. I have both an 89 and a 91 crx si chassis harness sitting in my floor and both of them have the red plug just taped to the main harness not plugged into anything.
2nd plug is for setting timing.
ucc crx's Avatar
if i just de-pin them do you think it would be fine?
Old Jun 4, 2010 | 01:23 PM
EFRue57's Avatar
why would you depin it and have loose wires in your harness? leave it in the connector and tape it to the harness like it came from the factory. if you want a pic of how it looks let me know and i can take a quick shot of it for you.
Old Jun 4, 2010 | 01:38 PM
ucc crx's Avatar
im trying to eliminate everything on the car and have individual relays for each. im just alil confused on these two plugs. im going to have a relay for low beams, high beams, starter, ecu, fuel, 02, fan, etc. the only thing that i haven't figured out is those plugs and the Voltage backup and brake switch that come off the ecu.
zduncan1
Engine Management and Tuning
Jan 31, 2013 03:15 PM
jksmith
Sep 29, 2009 08:02 AM
metalmachine
Mar 4, 2009 08:40 AM
nello a.
Dec 24, 2008 12:20 AM
hmtcrxsir
18
Oct 29, 2007 04:32 PM
