ABS Pump
Old Jun 4, 2010 | 11:05 AM
MC-130P's Avatar
Icon6 ABS Pump
Dose anyone know how to change the ABS pump motor, I have a light issue and it the pump is over ran thats what the code reads, I need to get the light to go out so I can pass me brake inspection for my registation.
Any help would be great.
I have a 93 2dr EX 5spd...
Old Jun 4, 2010 | 12:52 PM
sgraham01's Avatar
Default Re: ABS Pump
I have never heard of ABS being required for a brake inspection. I think you just need brakes, not ABS brakes. I would want to fix the light as well, but I don't think you should be required to have functioning ABS for registraiton. Where do you live?
Old Jun 4, 2010 | 08:09 PM
honccord1992's Avatar
i have a 1992 accord and the abs light is on. when i ran a diagnotic no code came up for what this problem is and ideals would help thaks.
Old Jun 5, 2010 | 05:30 AM
MC-130P's Avatar
Hey guys thanks for the replys, but in California you need a brake inspection for a totaled vehical and i already asked about it at the inspection station and they said that the light is a fail so I just need to fix it.
Old Jun 5, 2010 | 07:34 PM
did he say wht could be wrong with it or just a short?
Old Jun 5, 2010 | 07:37 PM
phootbag's Avatar
Most of the overrun problems I have repaired involved replacing the accumulator on the ABS modulator assembly. Not the entire assembly itself. Used ones can be faulty, so buy a new one.
The DTC you have actually means that the pump motor is running for a longer period of time than it should during start-up. The accumulator has a gas charged resevoir in it. If the gas has leaked out the pump motor won't shut off for some time causing this DTC to set. I bet this is your problem.
Old Jun 6, 2010 | 09:20 AM
I will defiantly look into that thanks for your help. ill let you know what happens when i get to that.
H22 CB
Suspension & Brakes
Oct 1, 2016 04:10 PM
b18LS
Oct 25, 2008 09:55 AM
blindman
Jun 23, 2008 05:01 AM
newhondaowner29
Jan 11, 2006 08:11 PM
f22suzuka
Apr 21, 2004 10:15 AM
