Euro-R swap problems
Old Jun 4, 2010 | 09:47 AM
jerseyh22accord's Avatar
Default Euro-R swap problems
Really just have 2 problems, the tach and cel dont work.
I have a 96 Accord w/ a 2000 Euro-r swap. Car starts and runs, but the tach doesn't move and the cel never turns on. And im running the stock PCD-014 Euro-r ecu
I found this thread:
https://honda-tech.com/forums/tech-misc-15/obd2b-obd1-conversion-tach-doesnt-work-2230515/
Which says to wire a resistor into my harness to make the tach work, going to try that in a bit when i get can get to the garage (no car since its at the shop). But also read some that if the tach doesnt work then the tach sensor isnt being turned on so that can lead to the cel not working. True?
Old Jun 4, 2010 | 11:16 AM
nus_dogg's Avatar
Default Re: Euro-R swap problems
Thats weird. You're using your stock F22 harness?
Old Jun 4, 2010 | 11:37 AM
I had hasport combine my f22 harness and the euro-r one
Like i said the car starts and runs, jsut coming across these two problems
Old Jun 4, 2010 | 01:35 PM
nus_dogg's Avatar
I would get a haynes manual for the H22 Prelude swap and trace the wiring diagram.
Old Jun 4, 2010 | 02:10 PM
92civlude's Avatar
Check inside the dizzy. The tach lead connector the side of the igniter probably is void of a wire. If it is, youll need to add a wire. the side of the igniter, (blue tach lead) to the blue wire at the dist. connector.
Old Jun 18, 2010 | 06:48 PM
2point6's Avatar
Bump please.
Maximus
Jun 5, 2025 09:26 AM
eg-ed
Nov 26, 2006 03:59 PM
GsrTurboCRX88
Mar 20, 2006 03:18 PM
1sikhatch
Feb 6, 2006 10:06 AM
NsX_CrX
Oct 27, 2005 08:57 PM
