High Beam doesn't "lock" on...
Old Jun 4, 2010 | 02:51 AM
7rrivera7's Avatar
Default High Beam doesn't "lock" on...
This just started happening - my high beams will come on when I pull the switch assembly towards me and the blue cluster light comes on but they go out as soon as I let go. They should stay on until I "click" them again but they go out as if the automatic "lock" isn't working.
Any suggestions on troubleshooting this issue short of replacing the switch assembly?
Old Jun 4, 2010 | 03:53 AM
spiceisler's Avatar
Default Re: High Beam doesn't "lock" on...
With your headlights on, push it forward instead. Your high beams should stay on.
Old Jul 9, 2010 | 12:08 PM
7rrivera7's Avatar
No, CRX's don't work that way. You have to pull the lever and the high beams should stay on until you pull the lever a second time.
Old Jul 9, 2010 | 12:43 PM
Nooch's Avatar
My highbeams lock when I pull them towards me, and I dont have a short nonlocking mode on my lever. Or mine is just broken, either way HIGH BEAMS locks for me on at least one mode. Maybe your lever lock is broken, try replacement maybe?
Old Jul 9, 2010 | 01:15 PM
7rrivera7's Avatar
I was trying not having to replace the assembly...
Old Jul 9, 2010 | 02:07 PM
efsex's Avatar
i'm having the same problem. Just go to the junkyard and pull the lever switch out of a ef hatch/sedan/wagovan. Should be real cheap
Old Jul 9, 2010 | 07:31 PM
DumpdEJ6's Avatar
I like the tuna here
My high beams were chancy at best, only coming on about half the time I pulled the lever back...now they don't come on at all. I took the switch apart and cleaned everything, but it made no difference. I didn't see anything wrong with the switch, I guess I'll change it out for a junkyard part and see if it makes a difference.
dlric
17
Apr 15, 2016 03:36 PM
scottsdale1977
Jul 28, 2014 07:32 AM
mikecp
Feb 20, 2011 08:52 PM
SLeePeR-STaTuS
Dec 8, 2007 06:40 PM
dc5mikeydc5
Apr 12, 2006 07:42 AM
