Gas pedal soft
Old Jun 4, 2010 | 12:18 AM
duyfash0's Avatar
Default Gas pedal soft
I have a 99 honda civic hatchback with b20 swap. I was driving on road and my gas pedal lost pressure and I had to floor it to make itgo. What's the problm and can I continue to drive it??
Old Jun 4, 2010 | 02:39 AM
mooze's Avatar
Default Re: Gas pedal soft
loose throttle cable...check to c if it came out of the mount
Old Jun 4, 2010 | 04:54 AM
duyfash0's Avatar
Where is this mount? Under hood?
Old Jun 4, 2010 | 05:31 AM
Stay*_*low's Avatar
If you don't know where it is then you should probably just take it to a shop! But if you look under the hood then there should be a bracket coming off of the intake manifold with the cable running to it.
Old Jun 4, 2010 | 09:30 AM
mayfly's Avatar
wtf. why does this forum get dumber and dumber everyday...1992-2000 civic forum=FAIL
Old Jun 4, 2010 | 10:04 AM
phoxking's Avatar
forums are for learning man and helping each other out man.chill..
Old Jun 4, 2010 | 01:55 PM
Stay*_*low's Avatar
If someone doesn't know where the throttle cable is, and whether it's even under the hood or not, then they need to find someone near them that can help them figure things out, and guide them along. It's much easier to have a someone with knowledge leaning over your car and pointing things out rather than trying to explain it in a forum. Instead of criticizing people, why not post some pics so that duyfash0 can learn?
Mike Antonetz
Transmission & Drivetrain
Jun 3, 2019 10:10 PM
x0!
May 30, 2008 01:40 AM
VietCloud7
May 6, 2008 04:46 PM
Yeung
Jun 3, 2004 09:12 PM
