clutch soanr work
is the pedal all the way to the floor board? If so, you can pull it back up but check if the clutch master cylinder is leaking. It's pretty common & if you look the clutch pedal (near the floor board) & follow it up. You'll see a leak....Other wise it's something else...
crayest thing ever it works fine now after sitting all nite got under there thismornin and blow the dirt tht was under there so see wht happens later today
flatblackintegragsr
Apr 3, 2006 02:51 PM
