ECU Pinouts NEEDED Del Sol odb1
Old Jun 3, 2010 | 07:01 PM
xero_xero's Avatar
Default ECU Pinouts NEEDED Del Sol odb1
Looking for the pinouts on a manual odb1 DEL SOL. has the stock d15b7. have the h22a ready to go in. Have a complete wiring harness for manual. have the peak and hold injectors with the resistor box. also have a gsr ecu to maintain the IAB. need a complete pinout for the odb1 ecu non vtec.
not worried with the complexities of the swap, just need the pinout and wire colors included.
ODB1 H22 Below
Layout
[A1-A25]--[B1-B15]--Blank--[D1-D21]
[A2-A26]--[B2-B16]--Blank--[D2-D22]
Pin---Color---------Desc.
A1----brn-----------Injector #1
A2----yel-----------Injector #4
A3----red1---------Injector #2
A4----grn/yel------VTEC Solenoid Valve
A5----blu-----------Injector #3
A6----or/wht-------HO2S heater coil
A7----grn/blk1-----PGM-FI Main Relay coil
A8----grn/blk2-----Shorted to A7
A9----blk/blu-------IAC Valve
A10
A11----red2--------EGR Control Solenoid
A12----blu/red-----Condenser Fan Relay
A13----blu/wht-----MIL
A14
A15----red/blu-----A/C Clutch Relay
A16----wht/grn-----Alternator
A17----pink---------IAB Solenoid Valve
A18----orn/red-----FAS (A/T)
A19----wht----------Intake Control Solenoid Valve
A20----red/grn-----EVAP Purge Control Solenoid
A21----yel/grn1----ICM
A22----yel/grn2----Shorted to A21
A23----blk1---------GND
A24----blk2---------GND
A25----yel/blk------PGM-FI Main Relay (power)
A26----blk/red------VTEC Pressure Switch (GND)
B1----yel/blk--------PGM-FI Main Relay (power)
B2----brn/blk-------GND
B3----orn1----------AFSA (A/T)
B4----pnk-----------AFSB (A/T)
B5----blu/blk--------To A/C Switch
B6
B7----lt grn---------ATP PN Gear Posisiton (A/T)
B8----red/grn-------PSP Switch
B9----blu/red-------Starter Cut Relay
B10---orn2----------VSS
B11---orn3----------CYP
B12---wht-----------CYP
B13---orn/blu-------TDC
B14---wht/blu-------TDC
B15---blu/grn-------CKP
B16--blu/yel--------CKP
D1----wht/yel-------Battery
D2----grn/wht1-----Brake Switch
D3----red/blu-------KS
D4----brn/wht------SCS
D5
D6----lt blu or lt grn-VTEC Pressure Switch
D7----lt grn/red----Data Link Connector
D8
D9----wht/red------ALT
D10---grn/blk------ELD
D11--red/blk-------TP Sensor
D12---wht/blk------EGR Valve Lift Sensor
D13---yel/blu-------ECT Sensor
D14---wht----------HO2S Sense
D15---red/yel------IAT Sensor
D16
D17---wht/blu------MAP Sensor
D18---lt grn/blk----VREF (A/T)
D19---red/wht------EGR Valve Lift Sensor
D20---yel/wht------TP Sensor
D21---blu/wht------MAP Sensor
D22---grn/wht2----TP Sensor
Old Jun 4, 2010 | 05:54 AM
xero_xero's Avatar
Default Re: ECU Pinouts NEEDED Del Sol odb1
bump bump bumpedy bump.
Old Jun 4, 2010 | 05:55 AM
xero_xero's Avatar
really really need a comperable comparison for the two.
Old Jun 4, 2010 | 07:18 AM
CivicSpoon's Avatar
It's the same, minus some sensors. It doesn't have the IAB wiring, the VTEC wiring, the EGR wiring, or the Knock sensor.
Old Jun 4, 2010 | 10:22 AM
jdmh22eg2's Avatar
DONT USE THE peak and hold inj and resistor box u will end up with mote issues than u can handle been there done that --if u do decide to use the resistor box and peak and hold inj u WILL have to use a h22a4/a (p13) ecu cause gsr ecu has resistors built into them and will never work correctly on a stock ecu
just find some reg (aftermarket) saturated inj around 350cc and use a stock del sol, civic manual harness and pin in the vtec, oil pressure switch, knock sensor, and secondary butterfly's done deal
Yoonit1
Sep 1, 2013 09:04 PM
cmwalker
May 21, 2013 04:49 PM
Username001
May 18, 2008 12:55 PM
