whats needed to get at least 1.6 60fts.??
i have 230whp 155tq. b motor in a eg hatch
23 mh slick
skunk2 rear drag springs on tokico blues
hasport mounts
tracktion bars
front suspensions are stock with just a coil over
ITR LSD tranny
and im only pulling 1.8 60fts.. wtf??
23 mh slick
hasport mounts
tracktion bars
ITR LSD tranny
Try launching higher and doing a quick, aggressive slip. New bushings may benefit you as well along with a traction bar up front. More seat time is probably the best advice anybody will give you. Just try new launching techniques to see what works best for you.
Any seasoned vet will tell you" SEAT TIME" is the key to success. Your 60's should get better with time. You can try an extra bump stop on the rear strutts to dampen the squat. try tweaking your suspension.
Suspension set up, good alignment, a good slick, and seat time. Make sure you are preloading and like everyone else said, slip it just a slight bit.....the preloading is key also.
Good luck, Be Safe!
Good luck, Be Safe!
-If you're bogging, raise the launch rpm and perhaps add air to the tires.
-If you're spinning, lower the launch rpm a tad, lower tire pressure and perhaps see if your tires are hot enough (I do 3rd gear burnouts for assurance)
Assuming your car's in the 2,100 to 2,200lbs. range with you in it and 230whp, I would suggest 8-9 psi in the tires, 7,500-7,800 launch rpm and as jdMhEaD said, PRELOADING is critical for good 60 foots and drivetrain longevity.
i had a jdm itr in my eg before. 7800 2 step launch and 7 psi worked for me. rev limiter was at like 8400 or 8600. if you're worried about a launching high because of a low rev limiter, at launch the car drops 1000 rpm but you dont know that unless you're datalogging. low 1.6 60' 12.7@108
acura_b18c1
May 21, 2008 07:28 PM
wleach11
Jun 21, 2005 12:12 AM
vtecmissle
Apr 26, 2004 08:28 AM
SIINSI
Mar 28, 2002 10:12 AM
