How to loop heater hose?
Old Jun 3, 2010 | 06:38 PM
JDM_addict's Avatar
Default How to loop heater hose?
Hi everyone,
I plan to delete my heater in my car by looping the heater core hose n block off some inlet/outlet for my engine(SOHC), I have seen some DIY's forum on how to loop/bypass the heater core hoses, but i cant retrieve it. Can anyone help me on this.? much appreciated.
Old Jun 3, 2010 | 07:17 PM
Jdmglenn's Avatar
Default Re: How to loop heater hose?
hook the one from the head to the one by the thermostat. and done
Old Jun 3, 2010 | 08:00 PM
unusual71's Avatar
YOu can block it off no problem. When the adjuster is set to full cold in the cabin then it is essentially blocked off anyways so no harm in cutting the hose and hose clamping a bolt into it.
Old Jun 3, 2010 | 09:07 PM
phootbag's Avatar
Why the hell do you want to do that?
Old Jun 4, 2010 | 11:02 PM
JDM_addict's Avatar
any pictures?
bcause my country doesnt have any seasons. It's always hot sometimes raining, that's all.. It's bad to delete the heater system?
Old Jun 5, 2010 | 06:54 AM
Red_Army's Avatar
no id just imagine they're used to seasons. like no heat here would be bad for winter but fine for your car.
Old Jun 6, 2010 | 05:28 PM
JDM_addict's Avatar
ok,
but does anyone got the DIY/pics on how to delete heater, loop/block the inlet/outlet?
Old Jun 6, 2010 | 06:13 PM
phootbag's Avatar
So, you want to get rid of it because you don't use it? I'd keep it. It's good to have in case you DO need it, it maintains resale value and it's a good backup heat exchanger in the event your vehicle begins to overheat.
Old Jun 6, 2010 | 06:55 PM
JDM_addict's Avatar
or i just block the hole on my head, n thermostat housing.? incase i sell it, i can still connect it back, for heater inside the dash, i jus leave it,
How does the "a good backup heat exchanger in the event your vehicle begins to overheat" works?
Old Jun 6, 2010 | 07:01 PM
Sr420Det's Avatar
u turn on ur heater and it releases heat form the engine coolant in the event of the engine overheating. if ur not hot Just dont turn the heat on, whats so hard about that. I mean u save no weight, and its not like u need a belt to drive it and plus more coolant in the system will keep it cooler.
Old Jun 6, 2010 | 07:12 PM
JDM_addict's Avatar
so that's how it works, but seems like my heater switch is jam, it stuck when i wanted to pull it to he heater side,
Old Jun 6, 2010 | 07:14 PM
phootbag's Avatar
Are you trying to block the heater off because it's always on and blowing hot air at you? I don't understand why you want to get rid of it.
Old Jun 6, 2010 | 07:17 PM
Sr420Det's Avatar
than look in the engine bay to the right of ur battery next to the charcoal canister (round black tube cylinder thingy with 3 hoses coming out of it) and ul c a cable running into ur firewall. the cable will b attached to this black valve that has two heater hoses runing into it. have someone adjust the hot to cold in the cab so ul know which way is cold in the engine bay, then just push it all the way to the cold side inside the engine bay. Be careful that cable and valve are kind of delicate and break easily so just dont use to much force
Old Jun 6, 2010 | 07:35 PM
JDM_addict's Avatar
no, cause alot of my local ppl did that, if u ever come to my country, then u will know the weather, we don need heater at all, our weather is enough to warm the car , my local mechanic told me that it will be fast for the air cond to cold up if i block the hot coolant to flow into the heater below my dash. Is it true?
Old Jun 6, 2010 | 07:56 PM
phootbag's Avatar
The heater valve will block the coolant flow through the heater core. You don't need to disconnect the heater for that. I don't think eliminating the heater core is necessary.
Also, you might want to find another mechanic.
Old Jun 6, 2010 | 08:57 PM
honda-junky's Avatar
^^^^Dude, You are such a hack!^^^^
OP Dont ever do this to your car.
That would almost be the equivelant of using duct tape.
thiendegigolo
Jan 25, 2011 08:29 PM
Frost_1097
Jun 5, 2007 10:21 AM
hks_Racing
Dec 1, 2006 02:50 PM
coot_er
May 14, 2004 01:52 PM
Sketch_hs
Dec 7, 2003 04:00 AM
