my problem is this manual connector at shock tower does not match manual connector has 7 pins and auto has 12 pins which i found a few and am stuck these wire left out maybe VSS wire in this cause that does not work reverse lights dont work and vtec i think i need help i prefer learning to help my self so i can help others so i chose DIY with help from others
Great thread thank you.
After many parts replacement (TPS, MAP, Injector, distributor, plug, plug wire, compression test and some more) today I found the culprit is an intermittent issue on middle-green white cable on MAP socket.
Question: can I safely rewire both 1. from MAP socket to body ground and 2. From ECU pin to body ground?
Hey man I know this thread is over a year old, but I'm such at the same spot as you were. I'm trying to swap harnesses in a 97 to the harness used on a f23a1 but don't see any pin outs for those two grey connectconnector information on your solution would be greatly appreciated 97 style plugs newest the fuse box 97 Again 98-00 ish that fit f23a1 harness F23a1 plugs
Any help would be greatly appreciated, I posted this question in my thread I started when I first began this swap journey. Like I said any information would be appreciated.
Reason: Added pictures
Did you ever figure this out? Doing a swap from auto to manual on a 02 my harness is from a 01 but c102 is different one is square one is rectangle? C101 and everything else plugged up fine
