Remove engine in order to remove steering rack?
You can get to the steering rack, but it is a pain. Removing the motor might be more of a pain tho...
depends on the scope of your maintenance. If you're looking to give the motor a full once-over, checkin out all the hoses and connections, it could be worth it.
you might be able to buy yourself some room if you drop the cradle out of the bottom. more room always makes any job a little easier. i don't think you have to remove the whole motor though...
i had to replace it on my del sol, well i was young so my dad did most of it, but i remember it was def a pita but very doable with the engine in, and we did it in the garage with no lift
joeramlowlol
Feb 9, 2014 05:50 PM
