water temp gauge rise when headlights on...
Old Jun 3, 2010 | 01:11 AM
arrowhead_vtec's Avatar
Default water temp gauge rise when headlights on...
my water temp gauge on my ek.... rises above normal when my headlamps are turned on... and it falls back to "normal" when i turn the lights off....
changed the 2 water temp sensors already, 1 which sends signal to ecu, the other to the gauge....
what else should i do? this is my 3rd speedometer, cant be all 3 having this same problem?
well, it only happens when i turn on my lights....
and i do have grounding cables...
help!
Old Jun 3, 2010 | 01:15 AM
mintonbt529's Avatar
Default Re: water temp gauge rise when headlights on...
do you smell antifreeze? if not then the lines might me crossing?
Old Jun 3, 2010 | 01:20 AM
mooze's Avatar
sounds like a voltage prob. when u turn the lights on they take away power from the fan causing it not to spin fast enough in turn allowing the coolant to overheat. check voltage coming from alt
Old Jun 3, 2010 | 04:21 AM
make sense but honestly i doubt so, the temp drops immediately after i turn off the lights, the temp wont come down immediately... or i could be wrong?
Old Jun 3, 2010 | 04:23 AM
mooze's Avatar
it should come right down once u turn lights off since fan can now run at optimum speed
Old Jun 3, 2010 | 04:48 AM
hmmm ok i'll get it checked... *headache*
Old Jun 5, 2010 | 01:33 AM
update: currently my temp needle didnt rise already...
solution: add more grounding, especially the ones for the headlights..
its been 2 days .. lookin good!
Old Jun 5, 2010 | 09:37 AM
Gunmetal_B20_Hatch's Avatar
was going to be my suggestion...
mnskateboarder
24
Jun 23, 2009 08:28 AM
mnskateboarder
Jun 22, 2009 01:11 PM
Project X
Sep 19, 2007 08:20 AM
Fighterinsnatch
Jul 22, 2007 02:38 PM
