My Itr still wont start!!
Old Jun 2, 2010 | 08:38 PM
killacam661's Avatar
Default My Itr still wont start!!
ok so i still cant get my 00 itr to fire up. the dizzy was tested and is good. im getting fuel. what im not getting is SPARK.ive double checked my grounds. tried different ecus. im using a ls harness btw, which i heard wouldnt be a problem.
One weird thing that happens is when i turn on the ignition my temp gauge goes all the way to hot. anyone have any idea?
Old Jun 3, 2010 | 07:21 AM
Tyrant_007's Avatar
Default Re: My Itr still wont start!!
I'd try an ITR harness. The LS harness doesn't even had the vtec solenoid plug. I'm sure there are other differences too. Checked the cap and rotor for corrosion?
Old Jun 3, 2010 | 08:14 AM
ricksintegra515's Avatar
Try your main relay
Old Jun 3, 2010 | 10:53 AM
MilFhunter001's Avatar
Originally Posted by ricksintegra515
Try your main relay
Crank sensor..maybe
Old Jun 4, 2010 | 06:32 PM
well the only missin sensor is the vtec and knock sensor, the rest are there. and im getting fuel so my main relay is good.... right? the car is a chipped obd1 and has knock sensor disabled.
dizzy was used on my friends del sol and worked fine
Old Jun 4, 2010 | 06:33 PM
Originally Posted by MilFhunter001
Crank sensor..maybe
the motor has 50k on it it was running when it in another car.im assuming its good
Old Jul 4, 2010 | 09:50 PM
baysic r's Avatar
did you get it started yet
Old Jul 5, 2010 | 04:33 AM
ek9dc2's Avatar
have you tried swaping the igniter. very common problem.
Old Jul 5, 2010 | 05:42 AM
esco115's Avatar
if ur temp gauge goes str8 to hot and the car never turned on... then recheck all ur connections and/or plugs u might of did something incorrect...
Old Jul 6, 2010 | 08:30 AM
mctype-R's Avatar
Your car can still start if the temp gauge goes right to hot. This means that the wire connected to the temp. sending unit is grounded or the sending unit is bad itself.
I would check fuse 9 under your dash. This would keep you from getting spark.
If you have the ITR harness I would put that back in. There could be some differences with the anti-theft system that may be causing it not to start.
Old Jul 6, 2010 | 01:16 PM
3s1k's Avatar
What ecu are you using?maybe the immobilizer. You said it was in another car so IDK what ecu your using or the proper key.
Old Jul 19, 2010 | 05:37 AM
delsolintegra's Avatar
When my 98 RS wouldn't start the reason was the upper tab button on the clutch pedal arm had broke and fell out and the clutch interlock switch wasn't being depressed when trying to start the car.
Have you noticed any broken pieces of plastic on the floor under the clutch pedal?
The upper tab button is hard to install. The lower one is simple but it's just a stop.
Old Jul 19, 2010 | 05:49 AM
LankorDie's Avatar
Loved
Community Favorite
I know it sounds dumb but take a step back and check all of your fuses, all your plugs, make sure every thing is correct and tight.
Old Jul 19, 2010 | 07:19 AM
94rs-turbo's Avatar
check to make sure the sensor on the side of the head is plugged in for the temp sensor or you could be using the wrong cluster back film.
have you run a compression check btw? what year ls harness are you running? I've had this problem before but can't remember what it was
smile_78905
Apr 15, 2009 05:05 AM
dcletten
Nov 7, 2008 09:50 AM
93Akkord
Jul 20, 2006 09:53 PM
Kangolbrand
Mar 12, 2006 10:43 AM
white91rex
Apr 29, 2005 11:45 AM
