Bypass valve and pcv box questions...
Old Jun 2, 2010 | 07:24 PM
2slowIntegraLS's Avatar
Default Bypass valve and pcv box questions...
My first question is does anyone know if you can or if it is smart to use an aem bypass valve somewhere in the charge piping of a turbo integra? Or if not in the charge piping, could I just put it after the air filter and before the turbo inlet?
My second question is about the black box (pcv box) on the back of the b series block. I already took it out b/c I am going to vent the crank case through two bungs on the vc. I just need to know what I should do with the two hoses that were on top of the black box? Should I just plug them? and if so what should I use to plug them?
Old Jun 3, 2010 | 06:13 AM
dpetro1's Avatar
Default Re: Bypass valve and pcv box questions...
you would absolutely not use a bypass valve/filter in your charge piping. it would create a boost leak because the boost pressure would vent out of the bypass valve and never reach the engine.
as far as the breather chamber. complete remove all hoses and pcv valve then cap any opening with rubber vacuum caps.
Old Jun 4, 2010 | 02:04 PM
Ok thanks thats pretty much what i figures but wanted to make sure. I appreciate it!
mr_gs-r
Dec 7, 2007 10:04 PM
yostuhfoo
May 16, 2007 09:43 AM
Boost2NA
Apr 1, 2004 12:56 PM
zCivic
Feb 17, 2003 07:15 AM
