Civic EG Head Gasket/Head Bolt
Old Jun 2, 2010 | 06:53 PM
cafine's Avatar
Default Civic EG Head Gasket/Head Bolt
I'm planning to change my head gasket this week, because i know it's burning coolant on it.
I already bought OEM headgasket, but not the head bolt cause honda don't have atm and need to do order from japan. And ARP Studs don't have any for my engine which is Dohc ZC 1.6 "EG5".
My question is can i still use my headbolt? I try to research on the internet and other's say that they don't have any problem reusing the head bolt.
And other's say that i need to replace it either the ARP Stud/OEM Stud, because it will brake down in some stage etc etc...
Any recommendation is allgud
Old Jun 2, 2010 | 07:19 PM
87 SiviK Si's Avatar
Default Re: Civic EG Head Gasket/Head Bolt
I have read that you can reuse the OE bolts, just torque them to 5lbs over the spec in the manual. the ARP head studs aren't reusable after the initial torquing. If Im not mistaken.
Old Jun 2, 2010 | 07:23 PM
nothing_shocking's Avatar
I strongly advise against it. I've heard people saying not to use them again, I've heard it's ok to use them, and I've heard that you have to mark which bolt came out of which hole and put it back into that one.
When it comes to internal engine stuff, I always say "why risk it?" Get the new ones and don't worry about it anymore.
Old Jun 2, 2010 | 07:24 PM
ARP studs are reusable something like 5-6 times I believe... I wouldn't see why they wouldn't be reusable since they're so fricken strong...
Old Jun 2, 2010 | 09:14 PM
cafine's Avatar
so example if the torque range is 10lbs i'm gonna make it 15lbs?
Old Jun 2, 2010 | 09:16 PM
cafine's Avatar
I want to buy new OEM Stud but they need to shipped it for 1 to 2week from japan.
Thxx for your advice, appreciate that.
Almarazjose
Jun 4, 2019 08:07 PM
esombra23
10
Mar 1, 2015 11:22 AM
germ49
Jan 21, 2013 05:34 AM
steveharrmr23
Jul 21, 2008 10:28 AM
n00b
May 20, 2005 12:49 AM
