CRX rear fogs
Old Jun 2, 2010 | 06:46 PM
uberEFtuner's Avatar
Default CRX rear fogs
I had a broken CRX center tail light section. So I looked inside. It has a perfect spot for fog lights.
My plan is to heat up the good one in the oven, remove the rectangle plate and cut a hole for a light socket. I,m going to use LED lights. It will be like a Volvo rear fog light built into the regular tail lights.
Old Jun 2, 2010 | 06:51 PM
90_EX_Civic's Avatar
Default Re: CRX rear fogs
http://img170.imageshack.us/img170/287/rearfogqy0.jpg
didnt think that us models had a spot for it. do it and post up a pic.
Old Jun 2, 2010 | 07:03 PM
crx_si-r's Avatar
Yes there are spots, but it might not work. Look at your broken kense there is an underside that will block out the light that would come from your "rear fog." it would be easier to convert the 90-91 style lights because the rear fogs are actually used in place of one of the reverse lights. You could essentially take apart a 90-91 center piece and add some red lense vynil or some glass paint and call it a day.
But I could be wrong about the 88-89 style lights that you are going to be using. Keep us updated regardless.
Old Jun 2, 2010 | 07:16 PM
k20rex's Avatar
id like to see how this works out
Old Jun 2, 2010 | 08:15 PM
Deetz's Avatar
Crazy Honda Guy
There are 2 styles of rear crx center tail light sections that came on EDM CRX's
88-89-
90-91-
Old Jun 2, 2010 | 08:55 PM
ninty1civic's Avatar
i tried to take apart a 91 center section before.. it wouldnt fit in the oven.. and there is hellllaa glue holding those things together..
Old Jun 3, 2010 | 05:10 AM
Jockone's Avatar
I have the center section with fog light to sell if anyone wants?PM for details I will try to look it out later today and get pics.
Old Jun 3, 2010 | 10:13 AM
lunalink's Avatar
in for the outcome
i_VTEC
19
Dec 28, 2007 06:14 PM
shevlin
Honda Civic (2001 - 2005)
25
May 10, 2006 10:16 PM
Hegster
Aug 2, 2005 12:15 PM
