engine wont idle until shifting from drive to nuetral/park
Old Jun 2, 2010 | 06:08 PM
dakota196's Avatar
Default engine wont idle until shifting from drive to nuetral/park
My 91 DX wont idle while in drive when stopping at a light. I have to shift it from drive to neutal or park. Once I shift from drive to neutral or park it will idle normally and stay normal when I shift it to drive again. Once I apply power it will drive normally, but when I come to a stop it will again idle high. It does this hot or cold. I have changed the IACV and FITV with new parts. I need help. Killing me in brakes and very annoying. Had a problem here in the snow, just would drag the rear tires with the brakes locked.
Old Jun 2, 2010 | 06:48 PM
jusabill's Avatar
Default Re: engine wont idle until shifting from drive to nuetral/park
not sure with your car but try the tps(throttle position sensor)could be that...............???????
Old Jun 2, 2010 | 06:51 PM
dakota196's Avatar
I'll look at that. Thanks for the help
Old Jun 2, 2010 | 06:55 PM
dakota196's Avatar
The car will start normally and idle and rev just fine. When you put it in D and drive it will drive normally, but when you let off the gas it will stay up in RPM's and stay there. You have to shift it in N or P. Could the re be a problem with the tranny computer or sensors? Just a thought.
Old Jun 2, 2010 | 07:14 PM
jusabill's Avatar
all tranny signals go to the computer.....so i dont think so .....definately one of throttle sensors.......try tps
Old Jun 2, 2010 | 07:30 PM
dakota196's Avatar
OK, but why only in a drive gear, fwd or rev and not in N or P?
Old Jun 2, 2010 | 07:55 PM
jusabill's Avatar
tps also senses a load on the engine and will ajust
Old Jun 2, 2010 | 07:57 PM
jusabill's Avatar
hope i was some help......good luck!!!!!!
Old Jun 2, 2010 | 08:49 PM
phootbag's Avatar
Have you checked the throttle cable for binding?
Exodeon
23
Jan 9, 2015 07:08 PM
istabrak
Dec 21, 2014 04:29 PM
dubedone
Nov 21, 2009 08:48 PM
raene
Nov 7, 2002 08:21 PM
