B series / Integra Type R parts
Old Jun 2, 2010 | 03:29 PM
MOVE OVER's Avatar
Default B series / Integra Type R parts
I need to clean out the garage. I will list some prices, but mostly, make a reasonable offer and you can have it. Buyer pays shipping or can pick up items. Located in Topeka, KS.
Used 98 ITR Clutch Master Cylinder $20
Used 98 ITR Clutch Slave Cylinder $20
Used rod and main bearings (brown, black, blue) from 98 ITR with 63k miles $5 for all
CUT OBD2a ECU wire harness $5
Used valve cover breather $5
Used 3/4th gear sleeve set from 98 ITR transmission with about 70k miles. Has some synchro wear (not visible as far as I can tell though) $10
GSR AC idler pulley - just pulley $3
Used / heavily worn 98 ITR AC idler pulley $1
New brass / greasable rear sway bar bushing D brackets (came with Mugen 26mm bar but never used) $25
Several old and worn B series torque mounts $3
Used but clean stock 92-95 civic coupe corner lights $10
Used 98 ITR Crank Pulley (AC outer rib is slightly torn due to an AC idler pulley bouncing off of it) $10
New 2.5" ID stainless pipe with flange - bought with Hytech replica header to eliminate CAT $20
Slightly used Exedy Stage 1 clutch - about 3k miles. Broken in properly and no track events on it. Looks New. $175
Used Pilot Bearings for B series Flywheel $2
Used throwout Bearings for B series tranny's - several with low mileage $2 each
Used 98 ITR timing belt auto tensioner (no spring)- $5
Lower alternator bracket and bolt (no bolt sleeve though) $5
Used 98 ITR Donut gasket $1
Used B series engine torque mount bolt $1
Used Red AEM True Power Alternator Pulley $15
Used 98 ITR power steering pulley $10
Used B series oil pan gasket $2
Used GSR? possibly prelude Leather shift **** - Great condition $10
Used B&M Shift Stabilizer kit $30
Used stock engine head ground - B series $1
Used stock main battery ground $1
Used main battery ground with high performance wire $3
Used 98 ITR timing belt and water pump - 63k miles $10
Used Aluminum Greddy Catch can and hose $10
Slightly Used 98 ITR Intake Manifold Gasket $5
Used 98 ITR exhaust gasket $1
Used B18c5 head gasket - free. Not sure if you can even reuse a headgasket....
Used 98 ITR oil pump housing - 63k miles $5
Used 98 ITR rear windshield washer motor and all parts $5
Used 98 ITR Fuel Pump $15
Used 98 ITR exhaust support bracket $2
Used Integra radio antennea wire $10
Old Jun 2, 2010 | 03:48 PM
thiendegigolo's Avatar
Default Re: B series / Integra Type R parts
pmed
Old Jun 3, 2010 | 10:49 AM
oyy0's Avatar
I'll take that wire harness and ITR oil pump housing, PM me with paypal addy.
Old Jun 5, 2010 | 11:18 AM
GeeReg's Avatar
PM sent.
Old Jun 5, 2010 | 11:31 AM
sh!ft's Avatar
Who the fack changed my title?!
pix of crank pulley please
as well as booster(s)
Old Jun 5, 2010 | 01:07 PM
travis-b16a2-eg's Avatar
bump for lookin.. good prices
Old Jun 5, 2010 | 08:10 PM
get RIGHT's Avatar
Bump for a great seller!
Old Jun 6, 2010 | 12:42 PM
MOVE OVER's Avatar
To all that PM'ed me:
I will respond tonight with pics. I have been away from home.
Thanks
Old Jun 6, 2010 | 01:40 PM
usdmEkb18c1's Avatar
can u send or post pics up on Used B&M Shift Stabilizer kit and greedy oil catch can n hoses!
Old Jun 6, 2010 | 03:03 PM
JDMInteg96's Avatar
ttt
Old Jun 6, 2010 | 03:58 PM
achtungm5's Avatar
I need a USDM Integra Type-r Catalytic Converter....If you have one please let me know please PM
Thanks
Old Jun 6, 2010 | 05:21 PM
TheAsian's Avatar
Can you provide pictures of the catch can?
Old Jun 6, 2010 | 06:30 PM
MOVE OVER's Avatar
http://img695.imageshack.us/i/imag0079qe.jpg/
Old Jun 6, 2010 | 06:34 PM
sh!ft's Avatar
nice iphone pix...now where r the booster and slave pix?
Old Jun 6, 2010 | 06:36 PM
MOVE OVER's Avatar
B&M shift stabilizer
Old Jun 6, 2010 | 06:40 PM
MOVE OVER's Avatar
Clutch Master and Slave
The master needs to be cleaned. Not sure what got on it in the parts box.
Old Sep 21, 2010 | 02:21 PM
davascript's Avatar
How nmuch for the synchro sleeve shipped to 14870 or 18407.
Old Oct 5, 2010 | 08:41 PM
Dwreck's Avatar
bump
B18cFreak
Apr 28, 2008 09:52 PM
IN VTEC
May 24, 2003 07:49 PM
