What does it take to make a 88-89 CRX identical to a 90-91
Old Sep 13, 2002 | 12:14 AM
Diversion's Avatar
Default What does it take to make a 88-89 CRX identical to a 90-91
I realize the headlights are different in the 90-91 and that allows you to use the cleaner (no screw type) corner lenses. The front bumper is different, will a 90-91 bumper bolt right up to a 88-89?
What about the taillights are different in the 90-91 verses 88-89?
Any other changes? Did 90-91 have power windows/mirrors?
I'm purchasing a 89 model and would like to change the parts to make it look cleaner like the 90-91 models. Thanks.
Jay
Old Sep 13, 2002 | 01:22 AM
FBPninetynineEM1's Avatar
Default Re: What does it take to make a 88-89 CRX identical to a 90-91 (Diversion)
all i can think of right now is, the front bumber, the corners (not sure if you can conver those though), the taillights, im pretty sure that all but there could be more stuff
Old Sep 13, 2002 | 01:24 AM
Reza^'s Avatar
1. the gauge cluster is different along with the cover above it.
2. 90-91 also has thinner side moldings.
3. rear disk brakes.
Old Sep 13, 2002 | 02:03 AM
91ED7Si's Avatar
Default Re: What does it take to make a 88-89 CRX identical to a 90-91 (EF8HOBO)
seats have different fabric..
painted mirrors on 91's
upgraded side impact door beams and door mounted seat belts..
different wheels
Old Sep 13, 2002 | 02:27 AM
RexB16's Avatar
Default Re: What does it take to make a 88-89 CRX identical to a 90-91 (91ED7Si)
door mounted seatbelts on 89-91
rear disk only on si
Old Sep 13, 2002 | 04:06 AM
Lt. Dan's Avatar
Default Re: What does it take to make a 88-89 CRX identical to a 90-91 (RexB16)
slightly hotter cam in the 90-91...
Dan
Old Sep 13, 2002 | 04:34 AM
E-AT_me's Avatar
Default Re: What does it take to make a 88-89 CRX identical to a 90-91 (Lt. Dan)
don't bother wasting your time.. that's just me.. but i sometimes can't even notice the difference..
spend the money one a GOOD suspension setup and header/intake/exhaust...
Old Sep 13, 2002 | 05:14 AM
USDM 4G VTEC's Avatar
Jay
yes all those parts will interchange except the corner lights..... and no, the only car with power windows was the 90-91 Sedan EX has that .. not on HB.....
Old Sep 13, 2002 | 08:32 AM
*Boostwerks*'s Avatar
Isn't that obvious?
Buy a 90-91.....
Old Sep 13, 2002 | 09:26 AM
SuperCivic's Avatar
Default Re: What does it take to make a 88-89 CRX identical to a 90-91 (Bryson)
89 ownz..if you're that concerned about it get jdm stuff.
Old Sep 13, 2002 | 10:24 AM
Malgerus's Avatar
Default Re: What does it take to make a 88-89 CRX identical to a 90-91 (SuperCivic)
The 89-91 have identical cams. 89+ have fuzzy gloveboxes, visors. different guage clusters. 90-91 have bigger clutches. 89-91 may have more aggressive computers too.
Old Sep 13, 2002 | 10:26 AM
Lamchop0000's Avatar
different wheels
painted side mirriors? mine arnt painted and also 3 other friend with crx's. oh well big deal.
Inaniac's Avatar
New User
Geez, sounds like the CRXs got a lot better in 90-91 compared to the 88-89.. What's the weight difference from 88-89 to 90-91? Thanks.
Jay
Old Sep 13, 2002 | 10:53 AM
Diversion's Avatar
Default Re: What does it take to make a 88-89 CRX identical to a 90-91 (Inaniac)
Also, is it me, or do the 88 CRX taillights look "fatter" ? Like thicker than the 89+
Jay
Old Sep 13, 2002 | 11:37 AM
Malgerus's Avatar
I wouldn't say CRX's got "better." Maybe more modern, but hardly better. The 88 still has the best rear suspension, and the 88-89 are significantly lighter.
Old Sep 13, 2002 | 12:34 PM
muskrat's Avatar
No door mounted seat belts in my '89.
Justin D. Fender
Old Sep 13, 2002 | 12:43 PM
slowman's Avatar
I took way too long
Default Re: What does it take to make a 88-89 CRX identical to a 90-91 (muskrat)
youd be better off buying a 90-91. just my opinion. my 90 si hatch doesnt have rear discs.
Old Sep 13, 2002 | 12:51 PM
reXem's Avatar
Default Re: What does it take to make a 88-89 CRX identical to a 90-91 (slowman EF)
hatches didnt get the rear disc only crx....my 90 crx has power windows but they are aftermarket power windows kit which is super sweet....my 1990 Crx has painted side mirrors, pillar mounted seatbelts, 89 dash cluster, rear disc, 90 front headlights, and there are more but I can't remember....my point is not every 90 got the upgraded stuph
Old Sep 13, 2002 | 01:04 PM
wuhungsixxx's Avatar
New User
Default Re: What does it take to make a 88-89 CRX identical to a 90-91 (reXem)
i have a 90 crx...i personally like the older look better...however the 90-91 si seatrs look alot better IMO
Old Sep 13, 2002 | 01:05 PM
New User
Justin D. Fender
my buddy has a 89 si crx...with door belts
Old Sep 13, 2002 | 01:15 PM
Timmah!!'s Avatar
Default Re: What does it take to make a 88-89 CRX identical to a 90-91 (wuhungsixxx)
89 had both, depending on the manufacture date
I dont realy want to see this discution come up again....
Old Sep 14, 2002 | 03:02 PM
E-AT_me's Avatar
Default Re: What does it take to make a 88-89 CRX identical to a 90-91 (azroth)
btw, the corner lights have NOTHING AT ALL to do with the headlights.. it's the FENDER, the way the mount to the FENDER.
i still say don't waste your money.. the only thing that gives it away is the front bumper.. check this picture:
http://www.geocities.com/c_rexman2/C...oey-dancrx.txt
you may have to copy and paste the link.
can you tell the difference?
[Modified by Rexman, 12:02 AM 9/15/2002]
Old Sep 14, 2002 | 03:05 PM
Hcivic88's Avatar
Default Re: What does it take to make a 88-89 CRX identical to a 90-91 (Rexman)
ones red with a black hood and ones yellow
other than that, i cant really notice much of a difference, im guessing the red ones the 90-91 though cause it looks slightly newer
Old Sep 14, 2002 | 03:09 PM
E-AT_me's Avatar
Default Re: What does it take to make a 88-89 CRX identical to a 90-91 (Hcivic88)
the red one's mine, 1990 Si..
the yellow one is Lt. Dan's, 1989 Si..
not big enough for us to tell..
yeah, it's got a gray ZC hood.. OEM JDM metal, too.. not some carbon fiber copy...
Old Sep 14, 2002 | 05:47 PM
Iceycrx's Avatar
turn signals, taillights, bumper,rims, some interior
