What Year is my D16Y8?
I'm rebuilding a D16Y8 I grabbed from an unknown car, and I'm trying to get piston rings, but I'm told the rings are different sizes depending on if it's a 96-98 or 99-00 manufacture. The only markings on the block are as follows:
D16Y8
2786999
Then on the back side:
P2E
1-2
Can anyone tell me what year or year range this engine is from? Or do I have to pull the pistons and measure my rings?
D16Y8
2786999
P2E
1-2
I guess the other question is do these two year ranges actually have different piston rings? I was looking on the Hastings website and they showed different part numbers for 96-98 and 99-00 D16Y8's, but according to the catalogue on hondapartscheap the Honda Part Numbers for rings for a 97 and 99 EX are the same. So I'm kind of confused.
interesting. i wouldn't expect them to be different, but i guess better to figure out what you have and be safe than sorry.
taken from here
https://honda-tech.com/forums/tech-misc-15/d-series-head-codes-786093/
"D16Y8
96 EX D16Y8 Auto------P2J-2 stamped 95 on rs of head
97 EX D16y8 5spd-----P2J-4 --- "97" stamped on the right
97 EX D16Y8 Auto-----P2J-6 "97" stamped on rs of head
97 EX D16Y8 Auto-----P2J-7
97 EX D16Y8 5sp-----P2J-6 "96" stamped on right side
98 EX D16Y8 Auto-----P23-2
99 EX D16Y8 5sp------P2J-4
00 EX D16Y8 5sp------P2J-3 "99" stamped on right side"
you will find this alphanumeric code on the front of your cylinder head
taken from here
"D16Y8
taken from here
https://honda-tech.com/forums/showthread.php?t=786093
"D16Y8
taken from here
"D16Y8
However, my head is marked P2J-2 and 97, which doesn't even jive with any of the codes shown in this listing. This is a Canadian vehicle/engine, so maybe the codes are somewhat different?
On the lower left side of the block, on the intake side, right above the oil pan, there is a green VIN tag, It is the same VIN as the chassis.
https://www.fleet.ford.com/maintenance/vin_tools/
type in the VIN on the site and it gives a generic break down of the car it came from:
Year, make, model, trim, country of origin, etc.
there should be a vin number on the front of the block there was on mine u can go to carfax and type that vin number in and it will tell u what year and mdl that engine came out of
Honda catalog shows the same part number for ring sets 96-00 for the D16Y8 which is 13011-P2F-A01. There are additional sizes for oversize for rebuilds .25 over and .50 over but they also share similar part numbers for 96-00.
taken from here
"D16Y8
taken from here
"D16Y8
JDMHondaEJ8
Oct 3, 2010 01:29 PM
