any1 else do a y7 swap in ef??
i put a y7 in me dx. used the obd0 sohc alternator and had to cut 1 rib off the y7 alternator belt for it to fit. any other belts can use? cause now my alternators maxed out on the adjuster but the belt is still loose. any other brackets or belts can use to fit good??
I used the stock alternator from the b16a2 (obd2) and switched out the plugs so i can use my stock CRX harness
works flawlessly
dont mind the ugly hole lol. i didnt have a dremel @ the time so i just rounded it with a drill bit lol
I used my old alternator and belt from the d16a6 I removed for my swap. Since the crank pulley is larger on the Y7, the alternator is pretty tight even before you tighten the bolts down.
The belt from my A6 is smaller than what the Y7 would have originally used (looks smaller by one rib). Not sure about how it compares to the DX tho. Works fine so far using the Y7's pulley and I've put over 1000km on my swap.
mixmastermatt
Mar 15, 2007 02:05 PM
Jet Black
Aug 21, 2005 05:55 PM
notfastenough
Sep 1, 2004 12:00 AM
irev210
Feb 22, 2003 09:14 PM
