Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Tein SS Coilover
Old Jun 2, 2010 | 08:05 AM
AndrewR18's Avatar
Icon6 Tein SS Coilover
Hi guys,
I am confused and I really need your help! I have installed a month ago my new Tein SS coilover on my Civic DX Sedan 08.
I have a problem. I can not adjust the damper. I put it in softer or harder, the hardness remains even. Somebody told me that if I put the damper to the hardest, it would be equivalent to throw myself on a minefield. However, in doing this is as comfortable as my original suspension, or almost!
I know I should not exceed 16 "clicks" recommended to avoid damage to the damper. By cons, if I cheat, I can fit 25 to 35 clicks.
Someone told me I had to make a quarter turn with the shock before installing, and this is the reason why I can not adjust the damper as I want.
Does anyone has had this problem?
Thank you very much for your help, it is much appreciated!
Mark
Old Jun 23, 2010 | 03:53 PM
jason10481's Avatar
Default Re: Tein SS Coilover
Hi Mark,
Did you buy them new or used? If used, they may need to be rebuilt. If new, I would contact Tein. They are a reputable company and should be able to assist you.
Best,
-Jason
Old Jul 9, 2010 | 09:21 AM
AndrewR18's Avatar
I have buy them new. I can them and they told me that everything is good lol... it is false, I can't fix the damper!
Old Jul 9, 2010 | 01:06 PM
Targa250R's Avatar
be professional
Whoever told you that was clueless.
Tein SS dampers do not build anywhere near enough force to make that much of a difference in ride quality on maximum vs. minimum settings. The adjustment range is well under a 100% change in force. The force vs. velocity dyno charts for SS dampers that I've seen show this clearly.
You should feel somewhat of a difference in damping when comparing the max/min extremes of the adjustment range back to back, but you shouldn't expect anything monumental. The SS are not exactly high-end performance dampers . . .
It is highly suspect that all four dampers would be defective at the same time. I get the feeling that either your expectations are out of line or you have not adjusted them properly. Did they come with instructions?
Old Jul 9, 2010 | 08:52 PM
michel99's Avatar
I agree with Jason that you need to talk with the Tein company technicians.They'll be able to guide you properly.
S2k Hybrid
Honda S2000
15
Jun 9, 2006 03:07 PM
cJ_EG2
Suspension & Brakes
Apr 26, 2006 04:28 AM
dre000
May 13, 2003 09:04 AM
MeanGreenEG9
Apr 25, 2003 05:34 PM
itr1094
Aug 27, 2001 08:42 AM
